433T |
Post Reply ![]() |
740Miller ![]() Bronze Level ![]() ![]() Joined: 17 Feb 2012 Location: United States Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Mar 2018 at 8:13pm |
Working on overhauling this motor. When pulling this down I noticed the two gears on the oil pump ride on a gear on the crank. Question? Is it normal for the teeth on the right gear not to engage the main drive gear? Confused? Me too. If I knew how to add a picture I would. Anyone's help would be appreciated.
Thanks |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22061 |
Crankshaft gear engages only ONE balancer gear. THEY HAVE TO BE TIMED !!!!!!!
That's what I'm looking at a balancer? Is there a timing mark on these or do I need to mark them before I pull it apart?
Thanks this is my first 433 |
LB0442 ![]() Orange Level ![]() ![]() Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
If you didn't disassemble the balancer you should just need the 2nd page.
Thanks this helped a lot, so it says to change the bearings. Any ideas where to get the correct ones?
Four- 74009919 needle bearings and possibly four- 4008917 thrust washers from an AGCO dealership.
Ooops....74008917 thrust.
Thanks Dr. Allis, I appreciate the help
Post Reply ![]() |
