PTO bearing shims
Pete32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Topic: PTO bearing shims
    Posted: 24 Feb 2018 at 9:29pm
After two days of struggling with the PTO oil seal on my WD, I finally won.  It's a good feeling.  I had to take the PTO cover(bearing cage?) off to get it out.  One of the paper shims paper shims tore when i was taking it off.
Are the paper shims also used as an oil seal or are they just used to maintain proper clearance?  Can I reuse it?  The one that tore was up against the PTO gearbox.  Are the paper shims still available or do I have to cut them and what material would I use?  I'm pretty green when it comes to this stuff.  Thank you- Matt
Dave76 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave76 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 10:12pm
I would get new gaskets they are available from DJS Tractor Parts. You might need two or three for correct gear spacing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 7:36am
Those shim/gaskets are the same that any standard 6 bolt truck PTO uses. They are available in thick and thin ones, use as needed to get the proper gear backlash.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 9:15am
I've gotten them from Agco, price was reasonable.
