Spring Trip Mounted AC Plows |
WNYBill
Topic: Spring Trip Mounted AC PlowsPosted: 23 Feb 2018 at 9:24am |
I have a set of 3 bottom mounted spring trip plows. One beam trips too easily. Book says to put a washer in it. I am afraid I will break something trying to get it apart. Is there an easier way?????
Bill
JimWenigOH
Posted: 24 Feb 2018 at 6:00am |
I don't know of an easier way. I'm a "do it by the book" type of guy most of the time. At least if something should break there are lots of plows at my salvage yard where I can get parts. If the job gets done right the first time, that's one less monkey on my back is the way I look at it.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 24 Feb 2018 at 6:09am |
I also believe in doing it right or don’t waste your time.
Mikez
Posted: 24 Feb 2018 at 10:52am |
Without digging into all my books, When I replaced everything in one of my plows I had the same trouble. Two books said differnt. One of the books said to just tighten up on the main pivot bolt a little bit causing some extra friction on the beam. It didn't take much
