Henderson Loader
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Topic: Henderson Loader
    Posted: 05 Jul 2010 at 10:08am
last week i bought a handerson loader for my C. the levers on the char-lyn pump seemed to be locked up. how do i go about treaing it apart to find out what the problem is? thanks
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 11:38am
take the rear cover off after you drain the oil [of corse ] that will expo se the valve body and the pickup screen also try taking the levers off ther held on with 1/4-2 0 cap screws slide the alum. holders off  the splined valve shaft may bin  put on out of time
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 6:17pm
after sending my other message I studied your photo  that loader used one way clys.I cant tell how yours hooked up the left side of the pump is for one way clys. the right side is for two way clys.  cant tell how yours is plumbed up.  post more photos will try to help some more  you have to have a vented plug on the pump not apipe plug or drill a vent hole in that one
Edited by pumpkin man - 13 Jul 2010 at 10:09am
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 11:37am
You need to use a splitter to go to both cylinders after you have a hose coming out of the 1 way port on that pump. As long as you have the original 1 way cylinders and they are hooked up to the 2 way ports the loader will not work. I'd show you how mine is plumbed up but it's in pieces right now awaiting a tractor to put it back on.
jk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jk Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 12:02pm
the cylinders are plumbed together with a T. i'll tear it apart in a day or so and post back what i find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 12:52pm
Yup hook it up to the 1 way valve then.
This page was generated in 0.046 seconds.
