interesting read (oil zinc levels)
ac45dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Topic: interesting read (oil zinc levels)
    Posted: 10 Feb 2018 at 10:17am
Iv'e been researching for oil to use in my old tractors so that I won't wipe out the cam shaft.Not to kick the bee hive, but does anyone have any suggestions.found this interesting article recently.whata yall think?
              [Editor’s Note: After the conversation following our introduction of the Hemmings Motor News Motor Oil last month, we turned to our tech guru, Jim O’Clair, for an explanation of the problems classic car owners have when choosing a modern motor oil.]
There has been a lot of confusion in the last few years about the lowering of zinc and phosphorus levels in modern oils and how these lower levels relate to classic and performance engines using standard flat tappet lifters – that is, just about every car built before the Eighties. The concern involves the use of the new lower zinc/phosphorus-content ILSAC (multi-viscosity) oils, readily available on shelves at auto parts stores everywhere, and how compatible they are with these older engines.
When anyone mentions zinc, they are actually referring to zinc dialkyldithiophosphate, a compound invented by Castrol for use in mineral-based oils or zinc di-thiophosphate (ZDTP), which is normally used in synthetic oils. Both have been used as an anti-wear ingredient in engine oil for many years. The zinc and phosphorus ingredients appear to be most effective when they are used together. ZDDP/ZDTP is one of many additives that are put into conventional motor oil to improve its lubrication qualities. Other ingredients such as boron and molybdenum are also added as lubricant enhancers.
What was discovered through oil testing by several engine component manufacturers is that many older engines experience a short period of time during engine start-up where critical lubrication is insufficient between metal-to-metal lubrication points when using modern oils with reduced amounts of ZDDP/ZDTP. These same enhancers unfortunately have their downside: The phosphorus in this compound creates carbon buildup in engine bores and valvetrains, and both compounds can also lead to the early demise of catalytic converters. For this reason, the industry has been phasing out zinc and phosphorus levels since 1994, when the American Petroleum Institute’s SH designation became the industry standard, and levels have been further reduced in each subsequent API rating for engine oils. Manufacturers have tried adding more boron to offset the effects of the reduced zinc and phosphorus levels; however, the dry start protection does not measure up to those using more ZDDP/ZDTP. This has opened up a whole new market for zinc/phosphorus additives for oil and many camshaft and engine manufacturers now recommend that an additive be used in initial break-in and for regular use.
All engine oils are rated for viscosity by the SAE as well as additive content by the API; passenger car ratings are two-letter designations that start with “S.” Heavy-duty or off-road equipment ratings start with “C.” The current API oil rating for passenger cars (gasoline engines) is SM and for trucks (diesel engines) CJ-4. Within these designations, you can determine how much zinc and how many other chemicals are present in the ILSAC (multi-viscosity) oils. These levels do not apply to straight-weight oils. If levels in the ILSAC oils are too high for the API specification, they cannot be rated for the current specification unless the container specifies “for racing or off-road use only” or “for use in classic cars.” This has caused oil companies to reduce levels of many additives, including zinc and phosphorus, to the required maximum in order to meet the current specification. Listed here are the current specifications for maximum amounts of additives to achieve the API ratings. P is phosphorus, Zn is zinc, and B is boron. Each figure is total parts per million of additives. These can also be roughly expressed in percentages by multiplying by .0001 (1301 PPM = .13 percent, 994 PPM = .099 percent)
API     P     Zn     B
SJ     1301     1280     151
CI-4     1150     1374     83
SL     994     1182     133
CJ-4     819     1014     26
SM     770     939     127
Most engine and engine component manufacturers recommend zinc and phosphorus content of more than 1,200 PPM for break-in; in fact, many will void warranties on camshafts or crate engines if this minimum is not found in the oil sample you supply when returning broken parts for warranty. For this reason, many manufacturers produce their own zinc additives or oils with supplementary zinc included; GM even offers its own break-in oil with additional ZDDP. With respect to readily available oil, you can see from the chart that, if you can find oil still on the shelf rated SJ or SL, you can use them, but you are right on the cusp of voiding a warranty. New SM oils are just not going to cut it unless they have a zinc additive to boost the rating and one of the zinc supplements should be used with these oils or oils containing additional ZDDP additives are recommended. Some enthusiasts have recommended using commercially rated CI-4 15W40 diesel oil to meet the zinc and phosphorus additive requirement; however, CI-4 is an old specification and hard to locate. You can see that the CJ-4 specification that now supersedes it is well below acceptable levels. Our best recommendation is that you contact your oil supplier for exact additive contents. Many straight-weight oils do not have to meet the ILSAC API specifications to be sold as SM or CJ-4, so this may be an alternative. Classic car oils with elevated levels of ZDDP/ZDTP are also being offered by many suppliers. Regardless, if you are purchasing off-the-shelf oil for your classic car, ILSAC multi-viscosity oils rated SM or CJ-4 should have stated zinc and phosphorus additive supplements for use in older engines or an additional separate additive should be purchased and used with the new oil. As the new API rating SN becomes available in the next year, even more caution should be taken as the levels will be reduced even further.
Edited by ac45dave - 11 Feb 2018 at 9:03pm
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 11:23am
Great article. I subscribe to an old car magazine.  For a long time they recommended Shell Rotella I think.  Someone please correct me if I am wrong.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 1:40pm
Thanks for posting about this Dave and I hope you don't catch the crap over like I did.lol
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 2:50pm
I have used Rotella 30 in my tractors for the last 35 years. Label says for use in older turbo and non-turbo engines.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 6:47pm
They are more concerned about those motors turning 8 or 9000 rpm than a 1800 rpm tractor. Use any modern oil sae 30, 15w40, etc and you will be fine. Been using F/S 15w40 in my tractors, combines, trucks, cars, and pickups since I brought the first case of it west of the Mississippi river in early 1977. I have run it over a million miles in trucks, thousands of hours in farm tractors, and hundreds of thousands of miles in cars, pickups, and mini vans with no engine failure of any kind.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 7:33pm
I have been using Shell Rotella T6 0W-40 in my B, because the diesel oil has more anti-wear additives and stuff in it (from what I could tell), the only other difference that I could tell from researching it was that the diesel oil didn't meet the cleanliness standards for modern gas engines, and this was the only big difference besides the better additives in the diesel oil. And so i figured that it didn't really matter for a 1939, and used it anyway. I am going to switch to AMSOIL Premium Protection though sometime, it is high-zinc specially made for older engines.
Just my opinion, I might be wrong though. Wink
- Ben
Edited by BenGiBoy - 10 Feb 2018 at 7:36pm
'39 Model B
Tractors are cheaper than girls, remember that!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 7:51pm
i've  been using Kendall 15W-40 diesel grade oil in every engine I own for the last 20 years with no oil related issues I know of.
A question does cranking the motor over some before letting it start reduce start up wear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 9:02pm
Well guys,I guess this is were I'm at.I've been using penzoil staight 30 in the gas tractors and rotella 15w-40 in the diesels for many years.the reduced zinc levels has been a concern of mine for some time now.I have had lengthy discussions with a well respected member of this site that has his own tractor repair business and is well known and respected for his engine rebuilding talents.He is seeing camshaft failures in these old 1800 rpm engines that he wasn't seeing before, until the zinc levels in the latest oils were getting reduced.This concern isn't isolated to just old tractors either.I guess my main question is, what oils are out there available today with 1200 ppm or greater zinc level.I just don't want to round the cam lobes off in my old tractors especially my wd45 diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 12:42am
isn't Penzoil....recycled oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 12:47am
not that I know of.I've never heard that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:38am
This has been brought up previously and I noted the changes coming as they were mandated to be introduced December 2016.
Oil you are buying now, unless you can find old stock prior to the manufacturing changes (pretty much gone), is NOT the oil you used to have available.
I ran this by a respected long time engine builder that I have used, before the roll-out of the government mandated changes and he advised anything he has built for years leaves his shop with a zinc additive installed or a small bottle on the pallet if the end-user wants to use his own oil for break-in. Touched base with him again spring 2017 and he advised folks were reporting issues if they did not add zinc and he recommended a couple ounces going forward regardless, new or old engines, every oil change . . . . .
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:42am
Anyone who says "I have been using brand X oil for years and I've never had any problems..." ,  is completely missing the point of this article. The bottom line is zinc and phosphorous levels (ZDDP/ZDTP) have been lowered in almost all oils over time, due to the changing oil classifications or specifications.
ac45dave, I've also read your later post that tested and rated 50 different oils, It was a very interesting read (as was this one).
Since I have two engines on stands right now, that are getting new sleeves, pistons, rings and bearings (main, rod and cam), I am thinking either a different oil or a break in additive is in order for these engines.
I am thinking out loud now, but we all know that a common cause of lowered oil pressure in the 201/226 engines is worn cam bearings. I am wondering if these lower zinc and phosphorous  levels are a contributing factor to cam bearing wear?
Edited by WF owner - 11 Feb 2018 at 5:43am
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 6:29am
WF - for break-in you'd be better off buying a motor oil that is designed for older engines. The concentration of zinc will be correct. It appears that too much is harmful. It also appears that cold startups are when much of the wear occurs.  All the more reason to use a free-flowing multi-weight synthetic oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 7:30am
I read an article in some farm magazine about 20-30 years ago where someone tested cold starts on an engine and found out 90% of all engine wear occured during cold starts. About the same time Consumer reports did a test on the frequency of changing oil.  They used New York City taxi cab fleet as their test base.   There conclusion was we spend too much money on oil changes as there was little difference between the cabs with different oil change intervals.  Seems like it was a useless test as cabs have very few cold starts over their lifetime.
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 8:59am
I use Amsoil Synthetic. Check out their Z -Rod oil for example its for older cars.... read about it...it's specifically designed for flat tappet camshaft engines that may sit more than they are used daily. Highly zink fortified. The zink acts as a sacraficial metal so upon start up it leaves the thin layer of zink to act as a wear component up until pressure or splash lubrication takes place.
You may have to copy that link to your Google box or browser search window but it's the technical service pdf that goes into great detail on the specific oil and what zink does to help out.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.amsoil.com/techservicesbulletin/MotorOil/TSB%2520MO-2007-08-08%2520Flat%2520Tappet.pdf&ved=2ahUKEwj656_vjp7ZAhVO1GMKHS9qC88QFjABegQIEhAB&usg=AOvVaw1Mcbr8MNsBuoEypW2Qkdl6
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 9:13am
Synthetic oil in the crank case and 100LL in the fuel tank mixed w just a small amount of two stroke oil to lubricate the exhaust valve's (due to 100ll being more of a dry fuel) and u are set. Protect the internals of the engine and protect the fuel tank, carb from gumming up and the entire fuel system.
Note: This may be more useful to collectors that have tractors that sit.
Unleaded gasoline is OK if u burn through it daily but other than that and it will make a person pretty frustrated when he has 20 tractors that won't run...the fuel tank looks awful inside and the carb is peeling like a sunburn inside with yellow varnish. In my opinion it is easily preventable. ...the shelf life on auto gas is 30 days. The shelf life on aviation 100ll is 7 years. That's a fact.
People will say...but 100 LL is so much more expensive....well take your tanks and carbs off...go through all that and do the math. If u are using the machines every day use auto...if they sit....use 100ll. May be the best thing you ever have done and really helps with the stress of keeping the mechanical integrity of collector tractors intact.
Just my 2cents...
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 9:15am
X2 what WF owner posted. Rotella 15w-40 is not the same oil it was a couple years ago, much less 30 years ago. Looks like all commonly available oils have had zinc properties lowered. We've started adding a few ounces of the Lucas zddp additive in conventional 10w-30 at oil changes for gas tractors.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 10:59am
Very interesting article.   I think what is missed in all the discussions here is that clean oil is as much the solution to engine longevity as treating the engine with care.  Change your oil frequently, and let your engine warm up and  cool down properly, and it will treat you well.  Abuse it, run oil too long between changes, etc and it will come back to haunt you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 11:53am
A local mechanic (with a very good reputation) once told me not to use synthetic oil in a new or rebuilt engine until the engine was well "broke in". His reasoning was that the superior lubricating ability of synthetic oil would prevent things from properly seating. He told me (and it kind of makes sense) that all new parts wear most rapidly when new, until they get worn to fit.
I'm thinking I might use a straight weight oil for break in, then switch to a multi-viscosity oil after the engine has some hours on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 12:26pm
WF. I would agree with that....in the Aviation world on recip engines we use a non detergent 100W mineral oil for the first 25 hours and then switch back to a detergent multi grade oil after that....I think of it as the engine is sort of finishing the machining process....the biggest part is your seat between the rings and cylinder walls. U don't want a lot of lubricity there or u won't get a good seat. If u were to use a straight grade or synthetic oil off the bat u may get excessive blow by on a new OH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 1:25pm
Consider that adding zinc to your break-in oil will, in theory, prevent metal to metal contact. This in itself would hinder the break in.  You could always pour Bon Ami down the carb, like GM had the dealer do with the first Chevy 265 engines. :)
Edited by DougS - 11 Feb 2018 at 1:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 1:31pm
I agree with DougS on the zink.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 2:02pm
I've heard of that being done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 2:09pm
Ford Explorer/Edge 3.5, 2.0 NA and Eco Boost, 2.3 Eco Boost, and 2.5 are all flat tappet cams. Nothing wrong with modern oil on a stock flat tappet cam. An aftermarket high performance grind, absolutely add the ZDDP to the oil.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 3:26pm
I think Lucas or even STP will leave a more protective film on the cams etc. They don't drip dry as much or as quickly as the oil without them. Some may believe they create drag on the engine. I've put a tac. in them before the additive, car in neutral, and in gear, engine cold and hot, checked the RPM both cold and hot. There wasn't a nickels worth of difference in the RPM. Checked the gas mileage, no change. Then I tried Slick 50 with the same detail. Had to slow the idle speed down 300 PRM if you can believe that much. This was a 400 CID carb. engine in a full size FW. I would have been much better off getting a six pack and set down under a shade tree. Now I do believe in the additives for cold start ups and long hard hot days. I also think that any engine that has cam in head is a good candidate for the stabilizer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 8:12pm
Just my 2cents...
steve, I never would have ever dreamed there was that much difference in the shelf life of regular gas and avgas,7 years wow!!the 100ll and two cycle recipe sounds like a collectors dream for long term stored tractors.
Edited by ac45dave - 26 Feb 2018 at 6:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 8:18pm
Ac45dave. You said it. I have stuck my nose in airplane wings w 100ll in them that have sat a few years...still smelled fresh..unleaded would of smelled like stinky old stuff and most likely could of caused a lot of expense to the fuel system to get it up and going.
I'm a believer in it. Makes sense to most anything for storage or minimal use. My last tank of gas in the lawn mower is that mix dirt bikes Etc
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 8:24pm
Brian not to dispute your knowledge but I would have to say the materials used in
the manufacturing of the modern day flat tappet engines are far from what was used in the fifties.I would think the lube requirements would differ greatly also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 5:41am
If, in fact, Ford is using flat tappets, they are shooting themselves in the foot as far as engine economy is concerned. You can do so much more with roller cams ar far as opening the valves more quickly. There is less friction too. In this day and age when they use 0W-20 oil and things like cycling the alternator for economy, I'd wonder why they would use flat tappets. If they are using flat tappets they've apparently hardened the cam enough to where enhanced motor oil isn't necessary. You won't find any auto manufacturer recommending oil with zinc if the vehicle, diesel or otherwise, is equipped with a catalytic converter.
