7020 Excess Smoke Followup- Ran it on a Dyno Today
Blustery Knoll Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Excess Smoke Followup- Ran it on a Dyno Today
    Posted: 08 Feb 2018 at 1:54pm
I finally got a chance to drive it up to my local independent mechanic to run it on the dyno. PTO output was 132 HP at 2300 RPM. Mechanic suggested that I have the injection pump rebuilt and replace the injectors, as there are several updates to both. Once the turbo spools up, the boost reaches a max of 10 PSI. His comment is that is right on the money, and these Allis tractors tend to smoke.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 2:06pm
What "updates" did he say the injection pump and injectors need? Boost number seems low to me.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 2:12pm
Boost number is very low. Should be 15 + at that HP number.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 3:24pm
not sure either about updates? For 132 hp it should have had 13-15 psi I'd guess, so at the 132 hp was it smoking heavily? That is only 9 over stock of 123, so I can't see that adding up. There's a problem somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 7:18pm
Yes, it was smoking pretty black on the dyno. It was an hour drive to get there. Tractor had a visible black smoke trail the whole trip there. Thick enough that I could see it out the back window of the cab. That's just bare tractor at wide open throttle in high gear, not towing any load.
If 10 PSI is not enough boost, where do I start looking? I have already checked all the air intake tubes before the turbo, and put in new air filters. Could someone have put the wrong turbo on it? If so, where do I look to find the part number to identify the turbo?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 7:22pm
From what I've seen/heard, yes, the Allis's tend to smoke. Especially the combines.
But it does sound like something is wrong, with only 10 pounds boost. The Doc and the others will get you fixed up I bet!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 7:39pm
I see that I can get a new turbo off of Ebay for less than $300. If I'm going to just start throwing parts at it, that seems like the cheapest place to start.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 7:40pm
I just re-read your earlier post, so that scraps my message about bird nest in air intake/filter.
Edited by AC7060IL - 08 Feb 2018 at 8:02pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 7:54pm
AC tractors do not smoke with premium #2 diesel. Black smoke is unburnt fuel. They are as clean burning as anything unless you turn the pump screws or have another problem. Good luck with your tractor. I hope you can find someone to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 8:59pm
Well, this is about enough of this posters 7020 engine complaints. I have taken the time to brush off the dust on my 7010/7020 Service Manual. From page A-137 are the dynamometer test specs for a model 7020 tractor engine.  NOMINAL PTO HP & RPM - 117.5 PTO HP @ 2300 ENG RPM ----- MAX INTAKE BOOST PRESSURE - 24 PSI -----  MAXIMUM EXHAUST TEMP -1200 DEGREES F* ------  TORQUE CURVE  (lugged down to)--- 106 PTO HP @ 1800 RPM WITH 19 PSI BOOST AND 1350 DEGREES F* EXHAUST.     These are the facts, like it or not.  "Nominal" PTO HP means that they may have been rated at 123 max HP at Nebraska test, but the average HP may have been a little less on some and a little more on others. If you tested ten tractors at the same time, all ten would be a little different. Max boost of 24 psi means maximum, but a number of 20 ish would be very normal and 10 sure as he77 isn't enough. Cooler ambient temps always make boost numbers higher. Normal boost numbers are usually rated on 70 degree ambient temps.   If the turbocharger shows no signs of any black paint on the compressor housing, it has been replaced with something. The turbo MUST be replaced with the exact CORRECT replacement for the engine to perform to these rated specs. They aren't like a loaf of bread....any will do. They are spec'd to an exact configuration.  Your technician might be a great guy, but he is somewhat ignorant on this 7020 engine when he says the boost is just fine. By the way, even running this engine when you know you are getting coolant in the engine oil is really asking for a hole to be punched in the block. I'm putting my Service book back on the shelf.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 9:40pm
DrAllis, thanks for the detailed info. It looks like I need to be focusing on the turbo, unless I can find a boost leak that has evaded detection so far. I don't recall seeing any black paint on the compressor housing when I changed the manifold, but I will give it a more thorough examination tomorrow.
I was a bit dubious of my tech's statement about 10 psi being enough boost, because of the previous discussions here. He is definitely not an AC specialist.
One thing I am thinking of now. If it's putting out 132 HP now with roughly half the proper boost pressure, what's the fuel screw set at? And what kind of power would it be turning out if it was getting proper boost levels? Am I right that the fuel screw must be turned up quite a bit to get more than rated power, with inadequate boost.
BTW, Dyno test was done with a 20 degree ambient air temp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 9:50pm
20 degree ambient temps with SUMMER FUEL in the tank would yield more HP but, with your low boost numbers I'd suspect he has an old M&W dyno which traditionally read 20 or so HP high at that HP range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 9:51pm
Also, testing on 540 instead of 1000 RPM makes it look better too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 9:56pm
You guessed right. He has an old M&W dyno, and I am running the 540 PTO. As for fuel, it's whatever the FS driver filled the farm barrel with in November.
What's the appropriate part number for the turbocharger?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 10:00pm
AGCO p/n 74009148 Air Research brand.  Maybe Injpumped can fix you up.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:25am
Very true but wasn't that another poster on a different 7020? Or am I just confused? Confused
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:55am
Yup....you'd be correct. It was another guy that started with a "B".....
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 7:39am
i dynode my 7020 a year ago it was turning out 126 hp at 1000 pto rpm and boost at around 19 psi, turbo had a nice audible whistle to it, not a lot of smoke, its all stock no tweaking of the pump. my opinion on those cheap turbos on ebay and what ive been told is to stay away and go with a good oem turbo bout $900 from agco WITH warranty!!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 7:50am
I have in the past got several turbos from Shoup, and had no trouble with any of them, usually much less than OEM Quite a few for 4440 Deeres, they seem to kill them for some reason...
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 8:20am
I can get new or reman turbos that are genuine Garret/AirResearch, not the cheap chinese ebay stuff that flys apart, and fills the engine with shrapnel. Does this have a muffler or straight pipe? If a muffler was plugged/broken inside, it could cause the issues. The pump being turned up 25% should not make it smoke going down the road. Going down the road by itself should not have loaded it any more than about 30 to 40 hp worth I'd guess. When the pump is turned up, you won't actually see that until you put more than 120hp load against it. There is some reason the engine is not getting the air moved thorough it like it should. Or the timing could be wrong, but it would be hard to start. I'm in N IL too. Where are you located, and who was the shop you took to dyno? I may know them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 8:57am
Ed, I do have a muffler. It was brand new, paint wasn't even burnt off when I bought the tractor. Previous owner said it had a cobbled stack op the cab corner that he didn't like.
Starts fine above 40° or so. Gotta be plugged in colder than that.
I am just east of Mendota. I will send you a private message after I take a look at my turbo and try to get a positive ID on it.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 9:20am
In my 2013 Shoup catalog, they show their part number AC8058 turbo fits AC 200, 7000, 7020 and combines L and M2, replaces 4007187 or 4008214. $689.00
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 1:04pm
I pulled the elbow off of the turbo and took a look. There's a fair amount of side play. On the intake side, there's a few scuff marks where it looks like the compressor wheel has made contact with the housing. There is no black paint anywhere on the compressor, and the only identification I can find is a casting number M11 and AirResearch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blustery Knoll Farm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:02pm
There's an intake manifold leak. If I spray ether at the gasket while cranking the motor, it will fire with the fuel shut-off pushed in. So, hopefully it's just going to cost me a gasket and having the manifold looked at by a machine shop.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:10pm
Make sure you didn’t rub a hole in the steel pipe between the aircleaner and turbo.
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:41pm
I'd say if there's any play in the turbo like you explained I'd think it needs replaced. Especially if it's hitting the housing.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 8:28pm
Valve adjustment can have an effect on how it runs and smokes. Everything has to be right on the money for the tractor to perform right I think the Doc said. You can tweak the pump. You do that and then it's the turbo. Then it's opening the valves up a little, then something else. Most mechanics today can't do that today. So you need to set down and figure this all out yourself, and ask questions like you're doing. Very interesting read and I hope you get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 8:31pm
Oh, I forgot, how many guys do you know that knows how to adjust the valves? Not very many I imagine.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 11:10pm
Adjusting the valves on a 301 are NOT done with the engine running...bring it up to operating temperature, adjust the valves by baring the engine over..
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 12:06am
As you correct these known issues (intake gaskets, turbo, valve adjustments, timing), it would be interesting to watch how it's dyno & boost perform differently per each fix. So maybe without fixing anything, drive it the hour to dyno. Dyno it again for a new unfixed baseline. Then wrench-in intake gaskets and dyno again. Then wrench-in new turbo and dyno again. Then wrench-in valve adjustments and dyno again. Then wrench-in timing and dyno again.
I know right, I asked for too much. PS- Take welding gloves to safely handle hot engine components while wrenching on it. #@&!!
This page was generated in 0.123 seconds.
