Late B Starter Rod Mystery
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Topic: Late B Starter Rod Mystery
    Posted: 04 Jul 2010 at 7:03pm
I recently purchased a 1951 B (SN 118xxx) which had the starter rod pictured below.  The starter switch lever was flipped, so this was setup as a push rod.  My first instinct was to flip the lever and change it back to a pull rod, then I realized why it was flipped in the first place - the rod hits the gas tank since it is straight.  I looked at the rod on my 1956 B and it has a bend just like a CA.  I have since replaced it with the CA rod in the picture, but I am stumped why the original rod was straight.  The top rod was definitely original and had not been modified.  Here is what the parts book shows.  I wonder if the top rod in the picture is 225588?  If so, was there a different switch lever used with this rod?  Thanks, Brian.
B:
70226015 1 ROD, starting (Used TR. B-113779 & UP) (Supersedes 70225588) (B)
CA:
70226015 1 ROD, starting motor switch
A-C Weight ID reference and other goodies at brianahart.net
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:20pm
My B,C and CA are all push start. The B and C are on the bottom and the CA is on top but a CA gas tank has an indentation for this and the B and C tanks do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:58pm
starter switch are all the same. you just turn the starter upside down, and rotate the head 180 degrees and reinstall. all are push start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:15pm
I use the term push/pull with respect to the rod, not the starter button.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:03pm
I must be nuts, but I THINK my CA is a pull arrangement......I'll have to check tomorrow and 'fess up if I'm wrong!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:07pm
My CA has always been pull  on the rod and the flipper pushes on the stater switch. My G was a pull start when I got it but it will start with the starter now. LOL
Edited by CTuckerNWIL - 04 Jul 2010 at 9:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:09pm
Whew, Charlie - glad to see some confirmation for my post.
WC, CA, D14, WD45
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:13pm
Mine is the same as Charlie's and Dave's.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:14pm
Brian, I would imagine the B's got changed to the pull rod some time soon after the CA came out. Yours might be one of those in between ones where they used up the tanks and rods left over from the B-C era which had a push rod start and no indent in the bottom of the tank. Since it is a 51 I would guess the push rod was original. Charlie
Edited by CTuckerNWIL - 04 Jul 2010 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:19pm
Maybe that serial number break wasn't exactly accurate.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:25pm
The early B , prior to serial # 113779, had the starter rod along side of the battery box, you had to push on it. The later B, after serial# 113779 had a pull rod like the CA.
So a 1951 would have the push rod down at the battery. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:33pm
Bob 113779 is a 1950 model. What Brian is saying I think, is he has a late 51 with the serial number after the break that has an early push rod set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:59pm
GEE, I had a B in 1953  that I thought was a 1950 and had the push rod. I guess it must have been a 49. So I guess that a 50 would have the pull rod. but then it should should have gas tank with the strap the same as the CA and with the indent above the starter. Parts manual shows tank change at the same serial # as starter rod. The older tank was discontinued. My parts book is dated 55.  Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 10:40pm
Charlie, I'm inclined to agree with you that it was an interim/transition setup.  To clarify: mine has the indentation in the bottom of the tank and the rod is in the same location as a CA (not the lower mounted rod found on earlier B's), just as the parts book specifies.  The only difference is that it was setup to push from the seat instead of pull.  Think of pushing on a CA starter rod from the seat.  My fix was to swap out the straight rod with a CA rod and flip the starter engagement lever.  Here is a picture:
