Allis C starter ring
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Topic: Allis C starter ring
    Posted: 04 Feb 2018 at 8:14pm
Is it common for the starter rings on the flywheel to have a spot that it grinds and every time it gets to that position? Just purchased another C and it grinds and doesn't hook up. Pulled starter and Bendix looks brand new and is not gummed up, shaft is not sloppy and starter itself looks like it was replaced recently. Starter went back in and lined up with coned bolt. Hooks up sometimes but seems to get to a certain spot and it grinds and have to stop and try again. This is the 3rd time this has happened with 3 different tractors. Just my luck or am I doing something wrong?
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 8:23pm
Yep.  Engine always stops in 1 of 2 places due to engine compression.  So the ring gear only gets used in  2 spots.
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 8:27pm
Replacing flywheel starter ring will fix this or is there something else to consider?
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 9:25pm
Replace ring gear.  Might as well rebuild oil pump while there.  That's what I'd do.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
This page was generated in 0.065 seconds.
