power take off adapter
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: power take off adapter
    Posted: 04 Jul 2010 at 3:41pm
several years ago, I ran accross a pto adapter that geared down a 1000 rpm tractor to run 540 implements. It was a round gear box, about 12 to 16 inches in diameter, that slid onto the 1000 rpm shaft, then had a 540 shaft sticking out the back to hook a 540 implement onto. It had to be chained to the draw bar to keep the gearbox itself from turning. It was the only one I've ever seen, and I am wondering if anyone has any knowledge of such a thing as to whether any company still makes something of that sort, or if they are all long gone. The reason I  ask is that I could really use one right now to run my 540 baler with my 8070. (It would have to go from large shaft 1000 to 540). I know that they make just a straight adapter to go that way, but I am not enthused about running the tractor engine way slow, or the baler too fast. I like the idea of the gear reduction. Any info would be greatly appreciated. TIA.  Darrel
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 4:22pm
They were made by Hub City. Not sure if the company is out of business but they don't make those adapters anymore. They were made mostly for Farmall Cub and Kubota that used the small pto shaft that ran engine speed and the wrong direction. I remember seeing a book that showed all the different configurations they had. There were 2:1 and 3:1 adapters. They are out there so just keep looking and asking around. I had one years ago but sold it. Now if we are on the same page here keep in mind they are a gear reducer therefore they will change direction of the shaft. Some applications it doesn't matter. If your does then you will not something planetary driven and I've never seen that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 4:45pm
If the thing fits a 1000rpm PTO and has an output shaft of a standard 1 3/8 540 PTO, I doubt it would turn backwards. There wouldn't be any use for it.  The company still makes PTO adapters. It was probably a planetary set up to reduce rpm so the would be no reason it would turn backwards if it was made to run a 1000rpm PTO at 540rpm.
Edited by CTuckerNWIL - 04 Jul 2010 at 5:13pm
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 5:30pm
It is a model 390 gear reducer. My brother is a Hub City dealer. I could check on a new price but I would guess about $600 minimum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 11:56pm
Nathan, I am very interested in one. If you could check with your brother on that for me, I'd really appreciate it. Thanks.  Darrel
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 9:06am
Nathan is Hub City still in business in Aberdeen?
ALLIS EXPRESS!
This year:
Tramway Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tramway Guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 10:11am
Darrel. He is gone today. I will catch him at work tomarrow.
Eldon.  Yeah they are still there.
