Rapco Brake Rivet Tool
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Topic: Rapco Brake Rivet Tool
    Posted: 04 Jul 2010 at 10:33am
RAPCO BRAKE RIVET TOOL
< =text/>
Brake Lining Installation Tool RA-825
Complete with: Rivet Punch, Set and Anvil for setting rivets. More Convenient and easier to use than most punch style tools.Will not crack or distort brake linings. Can be used in vise or hand held.
Description Part No. Price Buy
RAPCO BRAKE RIVET TOOL RA825 10-02065 $26.50
RAPCO REPLACEMENT PUNCH/ANVIL
FOR RA825
10-02066 $5.95
Hi,
Was wondering if it worked good on AC brakebands.  Read a review on this tool from the JD guys and it did not work well on JD brake shoes.
How difficult is it to rivet new liners?  any special techniques or suggestions?
Thanks in advance,
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 5:32pm
Looks to me like it would work fine. I just mount a flat punch in the vise and set the head of the rivet on it. the problem comes in when you need to hold the brake band level, the setting punch vertical and hit the punch with a hammer. I seem to always run out of hands.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 5:41pm
The reason it would not work well on jd's is because they use pads on one side, and a disk with 3 pads on the other side, and the tool will not reach far enough into the disk. It would work fine for the smaller pads, as well as pretty much an allis chalmers brakes.
I've done alot of john deere brakes. I mostly just use a small punch to mushroom the rivet out a little, and then a roll pin punch to set it, But i also agree with ctucker, you always seem to run out of hands. In college we had a prefessional press set up, and it worked slick, however you have to do alot of pads to pay for one. Most machine shops will rivet pads on for minimal dollars, and thats probly the way to go for most people.
