D17 frount rims ?
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Topic: D17 frount rims ?
    Posted: 03 Jul 2010 at 10:51pm
Hi to all, I would like to say what a great board you all have here. I went to a show in Rice Lake last weakend and now I am a proud owner of some old Allis news mag. and found this site. Anyway my dad and I have a small beef farm and have a D17 with a AC loader.  We had the tractor for 15 years and 14 years with a loader never had a problem this spring we put a new frount end on and dad got 7.50 16 tires the old ones were 6.50 16 the new ones did not fit unless we turn the rims the other way.  About a mounth ago I was loading bales on the bale rapper going good then about the 40th bale one of the frount rims broke, pulled right through the bolts finished with a swear word but starts with a John and ends with a deere. Anyway got to NEW rims 40 more bales did it AGIAN with the new rim. We got to new 6.50 16 tires put the rims on the right way now and havent used it much intill 2nd crop. My ? is do you think turning them rims around would do that? I think it would my dad says no way. Please tell me what you think Thanks Eric
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2010 at 11:03pm
we put 5 hole buick car rims on ours when it was used as a loader tractor they lasted longer than the factory rims
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2010 at 11:19pm
more sidewall with a 7.50 to shift weight? (bungi-effect)  and of course new rims are probably low quality
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:22am
The problem you are having is because the rims are turned aroud, which is fine, but the lug bolts are bottoming out on the hub before the rim is held tight and as it starts to move it cracks and fails, what you need to do is get a rim reinforsement ring, which you can get at Shoup, or a good tire dealer put that on over your rim using the same bolts and it will squueze the rim tight before the bolt bottoms out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:25pm
Some of the new replacement rims I've seen say right in the listing not recommended for use with a loader. It says so on the new rims I bought for my D17D. I don't plan to ever put a loader on it, so no big deal for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 1:19pm
Eric - they make HD rims for loader work.   An example is the one Tony @ Tony's Tractor sells - see link and scroll to the bottom.  You might check with Tony to see if these would work on a D17 with 7.50X16's or if he can source a similar but wider rim with the right offset to work for you.  Mike
http://www.tonystractors.com/acr.htm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 1:31pm
I'm with Mike. There are heavier duty rims made for loader work and the 7.50X16 tires need a wider rim than the 6.50X16's. I got my rims and tires (7.50X16's for my D15SII Loader tractor) from Miller Tire (they explained to me what I really needed); came all set up and ready to bolt on the front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 1:36pm
Thanks guys for all the help. The new rims were suppose to be heavy duty for a loader BUT looking at tonys web site just now the light rims are 65 and the heavy ones are 80. We paid 65 at downing tractor parts so I am gessing we got the light ones.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 3:37pm
Welcome to the forum!  You're only a couple of hours from where I'm from, Ashland WI.  I'm out in Kenmare ND now, but miss WI.  Good to see more WI people here.  Stick around, you'll learn a lot!
Good luck with your D17, that's a good tractor.  Dad has a D15 II, that we wouldn't get rid of for the world, good tractors.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
JCinPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 3:56pm
another issue that may or maynot be inplay in this event is that the bore on most rims have a square side and a radiused side.  If they are on so the square side is over the pilot the pilot carries the weight not the bolts.  If the rad. side is in over the pilot the bolts are carrying the weight-thus broken bolt holes.  JCinPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 4:07pm
Eric,
 Welcome to the best tractor site on the web.
 JC makes a very good point. If the face of the rim isn't seated against the face of the hub, I wouldn't expect the rims to hold up long at all. I would add, when the rims are offset out, you are also adding leverage to the equation. More leverage makes things break easier.
 Charlie
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 5:42pm
 We  have  heavy  fronts , the wheel center  is  thicker  than original rims  weigh  24 #. They are  welded all the way  around.  $80  + the ride.  fit  WC  on up to D-17  with 5 bolt  hub.  Thanks  Tony
