Allis 716 Motor Upgrade
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Allis 716 Motor Upgrade
    Posted: 23 Jan 2018 at 11:26am
I am going to rebuild the 16HP Kohler in my 716 Six Speed puller.  I was going to go with a Zack Kerber Gov 3 cam with the .330lift, and valve kit that he offers.  I thought that I may as well do this when I am in there.  I will go with a steel flywheel and front pulley as well as his reworked stock carb.  I guess that my question is, would this be too much for the rear end.  We are pulling what we call stock altered here in Ontario at 1150lbs.  I am running 26x12x12 puller tires.  I am looking to get enough power for a wee bit more speed.  I am going to put a straight shaft in the axle, and make sure the bevel gear box is up to snuff.  Thanks!!
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 7:49pm
Hey Kevin , you still lookn to build a llss/LPS
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 7:07am
Hey Mark.  I am.  I will give  you a shout here in the near future!  Cheers.
