wd45 12volt
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Topic: wd45 12volt
    Posted: 02 Jul 2010 at 5:32pm
Bought a wd45 with 12 volt alternator and battery, the coil is supposably from a d17, i know the lights won't work that way but will everything work or should i get the right coil and put a resistor on it?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 9:17pm
change the light bulbs to 12 volt and they will work. The D-17 coil might be a 12 volt coil, in which case you don'y need a resistor. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 10:04pm
Larry, do you have or can you borrow a digital ohm meter? A coil with 3 to 4 ohms resistance on the primary side is what you're after.  Before I converted both of my gas tractors to electronic ignition, I was using a coil from a Kohler K series engine. A ballast resistor can be added, but it is best in my opinion to use a coil that doesn't require one. One less thing to break...
