SHOW YOUR "B" IMPLEMENTS! |
Post Reply ![]() |
Page 12> |
DakotaSteve ![]() Orange Level ![]() Joined: 26 Apr 2017 Location: SD Points: 717 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jan 2018 at 9:16pm |
Thought it would be fun to start a thread where folks could share pics of their B attachments and or implements that were designed to be pulled behind and matched up to the B. I enjoy the little B! Snap coupler B pics from the back welcome!
This could turn into a great information source for all.
HaroldOmaha ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Omaha Points: 862 |
I have a set of inside rear wheel weights, all painted ready to go. will fit others besides the B, C, D10
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
I have an identical mower to that one, but mine has a single "C" size belt to drive it. Also have a pair of rear wheel weights, but that's all.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5147 |
Those mowers that have a double bet drive are a #5 mower. That is an improved version of the B/C mower that has the big single belt. The #5 will also mount on the CA whereas the B/C will not mount on a CA. I have 2 #5 mowers that could make one working unit available. I also have many other implement for B tractors available, as well as parts for them.
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
I used a Oliver 2-14 Rooster Plow for a number of years.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
A model "C" front bolt right on the B. You have to use the Grill from the C
Charlie
Simple video using the B/C Sickle Mower
[TUBE]gSFfAnkLBDQ[/TUBE]
Edited by Charlie175 - 02 Jan 2018 at 7:31am |
Charlie
Very nice. Creston....Don't u have a pull type No. 9 disc for a B as well?
Charlie175 Do u have a pic of the front of your B?
R.W....Great looking tractor.
1939Dodge ![]() Orange Level ![]() Joined: 18 Jan 2014 Location: Pa. Points: 554 |
I'm stil looking for hardware to mount a pair of plows to a B, if anyone has....
I mainly did it for something different and to be able to haul my D17 and B at the same time as the narrow fronts would overlap. To truly to get it to work right, the "C" steering box would need to be used to get the right geometry. As I have it, it steered hard. ![]() |
Charlie
The B/C Sickle and plow are simple designs, either hand lift or with the optional hydraulic ram
Charlie
The B Monroe seat was an option you could get.
Sorry for the divergence ![]() |
Charlie
Thanks Charlie
Wdtractorman ![]() Orange Level ![]() Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
Awesome! Keep it coming.
RLBPA1 ![]() Silver Level ![]() Joined: 04 Mar 2012 Location: Somerset PA Points: 286 |
39 B with 6 foot mower
53 B with plows. I had problems finding the B tractor hardware so I used one from a donor C
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88325 |
rear blade made from plow beam
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Had to join in. I hope a mower is considered an implement. One of my garage queens.
Edited by Hubnut - 02 Jan 2018 at 7:44pm |
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
Steve ill.....what is that big hydraulic cylinder?
Randy MN ![]() Bronze Level ![]() Joined: 03 Dec 2015 Location: Blaine, MN Points: 144 |
AC pull type implements and non AC implements!
34 WC #477, 38 B #1935, 1-116 on steel, #8 7ft dbl action disc, #9 5ft dbl action disc, 295 Chainsaw
Steve, yes, I have a No. 9 disc. (But the only photo I have is of my 8N pulling it) It's a bit newer than Randy's (spring loaded adjustment pins), but it's a 7 footer, and I'm thinking it would be a bit much for the B if I wanted to do any aggressive tillage. Haven't had a chance to try it out yet with the B, though. I know at the farm where the disc is, (extremely sandy soil) the 8N struggles to pull it. Has power, but without any weights, it loses traction and digs itself in a hole very quick. Of course, it wasn't designed for implements like that anyway.
Here's a photo of my B. Mower and umbrella are A-C, plow is an Oliver 2-12 rooster lift, like was already mentioned. Pulls that plow very nicely in all soils, but struggles for traction in the sticky gumbo that plows like asphalt just a few miles west of me. Oh, also, Steve...it's a '42 war baby. Well, supposed to be anyway. ![]() Edited by CrestonM - 02 Jan 2018 at 9:33pm |
Very cool Creston! My war B is a 42 as well it would be interesting to see what your sn is and what the AM dash number is on the side of your block....should be a -13 or -14...
Post Reply ![]() |
Page 12> |
