Anyway to put a valve stem on
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Topic: Anyway to put a valve stem on
    Posted: 01 Jul 2010 at 5:43pm
from the outside?  I just blew one off my dad's Case tractor raking hay.  I'm not a tire expert but am pretty sure it needs to be removed from the rim right?
Thank you,
Byron
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 5:49pm
'fraid so!
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 6:23pm
Tubless? If so you just need to break the bead on the stem side to be able to reach in enough to get another started in the hole and pulled through.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 7:56pm
I just did 2 on a 3415 Simplicity, just like wkpoor said, used a little Murphy's Oil Soap. Made them slide right in.
Dusty
This page was generated in 0.052 seconds.
