12 volt 1 wire alternater
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt 1 wire alternater
    Posted: 23 Dec 2017 at 3:25pm
How do I know if my alternater is working?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 3:49pm
look at the ammeter ? not trying to be smart but an ammeter will show charge and discharge. A voltmeter won't tell you that and it could be a long time before is gets low enough to say 'oopsy'...
you could turn on all the lights  and see/hear what happens when you rev up the engine a bit, lights getting brighter is a sign the alternator is possibly working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 4:15pm
If you measure the voltage you should be about 13.8 or so if working
depending what type of alternator you have will depend on how to test - but on the older 10si units there is a hole in the back cover that looks like a mouse hole (U upside down) - by taking as small metal tool and grounding the tab behind this hole it will bypass the regulator and full output the alternator .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 4:16pm
Thank you jaybmiller
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 4:18pm
Thanks to the guys also for the help
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 4:51pm
Get yourself one of those 6 light testers from Advance Auto or off ebay they'll
test it.They have a magnetic back so you can leave it on something while you're running
the tractor.Around $10 or $12
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 5:13pm
for a quick test on any car/ truck/ tractor , I just measure the voltage across the battery terminals with motor off.... should be about 12 - 12.6 volts .... then start the truck and  again measure the battery voltage... should be 13.8 - 14.6 volts.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 5:56pm
if it's a gas burner or propane, just unhook the ground cable on the battery!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:54pm
For a starting battery with with full charge specific gravity of 1280 the full charged voltage is 14.200 volts at 68 degrees F. Pushing a greater voltage like 14.6 guarantees overcharge and loss of water from the electrolyte. The charging voltage can rise a little from 14.2 for higher and lower temperatures. That is at the battery posts. If you use a voltmeter somewhere else in the wiring the voltage will be higher because of voltage drop in the charging wiring.
The best indicator is the ammeter. After starting the charging current will be maximum, and if the voltage is regulated properly will taper to zero as the battery gets fully charged. The ammeter must be wired so that the charging current goes through it and also all equipment loads like lights, ignition, fans, etc that are discharging currents go through in the opposite direction. For negative ground the negative post on the ammeter goes to the positive battery post. The alternator and all loads but the starter are connected to the positive post on the ammeter.
Sometimes you can see the effect of the alternator charging on the brightness of the lamps but that can be subtle.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 9:13pm
Touch the back of rear bearing with knife blade. If it is a magnet it is working.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 5:32am
X2, on what mack says.  However it can magnetize, with a bad  diode or diode cluster(internal regulator)
Do NOT pull the ground or hot wire off while running, this will blow the diodes in an alternator.  Might be OK to do on a tractor with a generator, but NOT on one with an alternator...Wink
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 10:44am
Yeah, diyDave is right. I pulled the battery cable off.my Town Car one time.to.see if it was charging and blew the ecm computer out. 365$ just for the part. Expensive lesson!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 3:29pm
Jay is right to a certain extent.  Here's what you need to know. Pretty simple. With a Voltmeter installed the normal charging rate is 13.9-14.5 Volts. 14.2 being ideal. If the needle is in that range, your good and everything is normal. If you make a habit of monitoring the Voltmeter, and its showing a charging rate of below 13.9, its undercharging. This will bring to your attention that the charging rate is down and the Battery and the system is not getting charged correctly. If its above 14.5 its overcharging, and there's something going on to cause that. Pretty simple. No guesswork involved. You don't have to be an electrical engineer or master mechanic to understand that.  Now, if there is a short (load) on the system, the Voltmeter will show a very high charge rate telling you something is going on and it needs to be looked at ASAP before smoke and flames appear. Now here is where Jay is correct. With an Ammeter down stream of an Alternator, if there is a short, the Ammeter will let you know theres a problem even quicker than a Voltmeter because its already burning and on fire in the instrument panel that's located between your legs. So yup, the Ammeter will actually show you more than a Voltmeter would. No doubt about it..... Thumbs Up
Steve@B&B
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 7:46pm
I have often wondered why GM continued to make multiwire alternators and use them on millions of cars and trucks long after the 1 wire setup was figured out.  (?)  Call me paranoid, but I have always used the multiwire alternators when doing a conversion.  My thinking -- must be something "negative" about the 1 wire alternators.
Chris in NE Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 7:52pm
Another way to check for charging is to pull on your headlights and see if they brighten even a bit when you throttle up from tick over speed.  Granted, this method is more qualitative then quantitative.  And works way better when it's dark out.
Chris in NE Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 9:10pm
The multiwire alternators can easily be wired so the internal voltage regulator works off the voltage at the battery or near the battery so that voltage drop in the wiring is compensated for to get better battery charging and starts charging with the engine at idle as soon as the engine is running and power is applied to the alternator start terminal. A one wire alternator samples the voltage at the alternator output terminal and so doesn't compensate for voltage drop between the alternator and the battery and the one wire alternator doesn't start charging until it is spun up. One spun up it charges down to idle, but on my gas 4020 with the smallest available alternator pulley and something like a 7" crankshaft pulley it takes about 1650 engine RPM which may be over 5000 alternator RPM before it starts charging. That need for goosing the engine doesn't always make the simple wiring profitable.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2017 at 10:05pm
Your thought process is correct. A three wire Alternator wiring system is always better than a one wire setup.  With a three wire unit, you monitor the system with the voltage sense circuit. The Voltage regulator does its job in keeping the system (and the Battery) fully charged because it adjusts the Alternators output through the voltage sense circuit.
A much more accurate and effective system in keeping all functions operating the way they should, at the same time keeping the Battery happy.  A happy system is a reliable system.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 9:18am
The one wire alternator is easiest to install, but I'm not sure goosing a cold engine to get it to start charging is a great idea for engine life. And if you use the generator pulley rather than the smallest available alternator pulley it might take goosing the engine above its rated maximum speed to get the one wire alternator to start charging. Once started it charges pretty good all the way to engine slowest idle speed.
Gerald J.
Edited by Gerald J. - 25 Dec 2017 at 12:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 11:43am
I've used the CS-130 series of alternators, configured as 'one wire' and never had a problem( knock on wooden head..) HOWEVER I also used brand new wiring during the conversion. Have to think the IsquaredR losses can't be too much for 4' of wire.
hmm.. I need an 'excuse' to buy some $2 voltmeters, be interesting to see how well they work.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 7:42pm
Jay
The only people that don't like one wire alternators and claim they won't work it seems are the ones that don't use them.I'm
running 8 right now on tractors and have found most of the 'faults' supposedly with them
to be totally untrue.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 8:25pm
Jay
I2R loss can be significant at 30 AMPS, even with 4 feet of wire. A half-volt loss may not seem like much when you put it to a component, but it is significant when you calculate the effect it will have on charging a battery.  The good news is that as the battery charges, the current through the wire drops, reducing the I2R loss. When the battery is charged to the point that it is only calling for 5 AMPS, the voltage drop will be insignificant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 12:10pm
The one wire alternators have a small parasitic draw when not running. If the tractor is used regularly it's not enough to matter, if it sits long term they will drain the battery. The 3 wire system uses a voltage sense wire and a signal wire. The signal turns the regulator on with a B+ signal through a bulb from the ign switch. When the regulator is working the bulb will have B+ on both sides. There is also a 500 ohm resistor across the bulb so in the event the bulb burns out, the regulator still gets a B+ signal, but the 12v from the regulator won't be able to power anything on the ign switch.
2 wires from the regulator are now used for ECM control of the voltage, not necessarily the turn on signal. GEM MON and GEN COM. MON is the ECM's feedback from the regulator, COM is where the ECM commands the voltage set point. The days of over 14v being considered overcharging ended back in the late 90's. In extremely cold weather the ECM will command up to 15v to increase recharge rate and warm the battery.
If the regulator sees no signal from the ECM but detects a spinning rotor, usually above 1500 RPMs, the regulator will set constant at 13.8 IIRC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 4:02pm
Gerald J.
You need to get one of the good 1 wire alternators off ebay for $60,I have 8 on
tractors and every one will start to charge as soon as the engine fires up no matter
how slow the throttle is set.Fired up the AC 185 today to see how'd it'd start after sitting for over 3 weeks fired right up and starting charging with the throttle slightly cracked
up from idle.Battery didn't run down either in 3+ weeks(anther 1 wire myth).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 8:19pm
I don't know if you're referring to me with the comment on the people who don't like one wires is because they don't try them, I've had many a one wire on race cars, hotrods, etc. That's one of the main reasons why I tell my customer's to use a 3 wire. Has nothin' to do with not using them. Has all to do with handling loads in the system much more efficiently. The more loads you have in a system, the more you should be running a 3 wire system. Hey, if you're having good luck with the one wires on your Tractors, great.  I not saying they don't work. They work more efficiently when the regulator can monitor the system when larger loads are put on the system. Obviously, you're not using a lot of power on board your Tractors while their running so they work for you. Nuttin' wrong wit' dat'....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 9:10pm
Most old tractors have very little current draw almost none if its a diesel unless the lights are used and if they are replacing a generator then any alternator is going to supply way more power than any generator ever did.When I started the 185 today it charged a lot for maybe a minute then the needle dropped back after it had charged the battery back up.So it must be 'monitoring' what needs current.
An Old  tractor ain't a fully loaded 2017 SUV so you don't need the same electrical
capabilities.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 9:13pm
The battery sets the charging current providing the generator or alternator voltage is regulated at 14.2 volts. As the battery charges the current decreases to zero when the battery is fully charged. The alternator regulator just controls the voltage for that to happen. A three wire alternator can be wired so the regulator senses the voltage near the battery so that wiring voltage drop isn't a factor.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 5:12am
Gerald J.
So if you think the 3 wire is so good why haven't you put one on the 4020?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 9:57am
So far the one wire has worked adequately with simple wiring and with the small alternator pulley doesn't require over speeding the engine (only about 1650 rpm) to get charging started. The one wire I have can be connected with three wires. I used 10 gauge wire from the power connection of the alternator rated at 55 amps. I used silicone insulated wire because it would run hot and is close to the engine block. The resistance of that wire limits the peak charging current to about 35 amps according to the ammeter that I added to the 4020. That is not full performance for the alternator, but the original generator was only 20 amps so its a definite improvement on the 4020 gas original design.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 11:21am
Go on ebay and get a one wire one from DB Electrical think you'll find that to be
better,definitely will not have to rev your engine up to anything close to 1650 RPM
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 12:20pm
Put one from DB on my A.C. 620 with the failed charging system.  Stuck a volt meter on it in place of the ammeter, and starts charging as soon as engine is running.  Sure is a welcome change.  Have had it on for a little over a year, with a small garden tractor battery replacing the big auto size battery that was in this series tractor.  Seems to work well.  Has a snowblower on in the winter, and is not run very often, yet still seems to start well.
This page was generated in 0.091 seconds.
