WD Camshaft Gear
codyrandall21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote codyrandall21 Quote  Post ReplyReply Direct Link To This Post Topic: WD Camshaft Gear
    Posted: 20 Dec 2017 at 9:46pm
I recently inherited a 50' WD with a house I bought. It is in pretty good shape but does need some work. The one problem that I have run in to is that I need to replace the Camshaft Gear. Mine has the bolt on gear, not the press on. I have searched high and low. I've found 100 press on gears for every 1 bolt on. The handful of bolt on that I have found are very used, being sold attached to the Camshaft and are $160+. So, my question(s): Is there some reason I can't find the gear I need? Does anyone know where I can find one? Is $160+ really what I'm going to have to pay for one gear? Would a camshaft with a press on great be compatible in my engine? Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 10:11pm
Yes, change cam and gear. Just make oil pump gear matches.    MACK
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 8:28am
Cody...I sent you a message.   Rick
