160 Hydraulic Remotes Valve
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: 160 Hydraulic Remotes Valve
    Posted: 30 Jun 2010 at 7:08pm
Hello,
Our 160 has what I believe is a sticking pressure relief in the remote valve assembly.
I have torn the valve apart once, freed the stuck piece (it was rusted in place) polished it and put it back together, this worked for a few weeks but not it is acting up again. I'm planning to tear into it again soon but was also wondering if anyone has one of these valves for sale, ours is the single remote valve but we would be even more interested in the double valve if it would bolt up.
If no one has one of these for sale I would also appreciate any advice on what to do differently next time I have it torn apart to prevent future problems.
Thanks,
Erik Fellenz
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 8:28pm
take it apart again its just dirt in it.  Have you changed the tranny/hyd oil ?  you may have a bounch of stuff in it.
160 CA 920diesel 5020 HD-3
allisd2112 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 8:49pm
I have a 160 that I parted out. by looking at it I think you could bolt this one on to yours to make a double valve. maybe some one else knows. let me know if Interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 6:52pm
allisd2112,
I'm interested in the valve you have, I won't have a chance to tear into this tractor for probably another week or so but will take pictures when I do so you'll be able to see if there are any differences that would cause problems trying to bolt up the dual spool valve.
How much are you asking for the valve? Was it working correctly before you parted out the tractor?
I am also looking for seat parts, a new dashboard, sway bars for the three point, an OEM top link and the steel mesh that is welded into the front of the hood if you have any of these parts.
Thanks,
Erik Fellenz
www.fellenzfamilyfarm.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 9:02pm
I may have some seat parts,none of the other things. I'll take 75.00 for the valve. tractor was non running when parted.If Interested you can have the rear end and trans and all motor parts and every thing else for 500.00 need the room!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 7:09am
Email sent.
Thanks,
Erik
