Winter projects
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Winter projects
    Posted: 17 Dec 2017 at 6:44pm
Decided to rebuild all my headlights on my tractors. Now that the reflectors, gasket, and other parts are available, it makes a nice light when finished.
Got 16 done. I think I am almost half done with the early tractors before 1960. I will see how this goes before I start on the later ones.
How is your project going?
 1
Edited by Lon(MN) - 25 Dec 2017 at 7:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 6:48pm
Wife flooded the basement AGAIN.... don't ask...
Oh yeah... next Monday is Xmas...just found that out...
basement might be dry by then...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 7:07pm
Lon , how about a couple pictures and parts list of what you used for the pre 1960s ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 8:50pm
I can take some pictures, but don't know how to post them on here. I can email them to someone if they are willing to post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 8:57pm
Well, the 190 XT is finished up. I received my rebuilt hydraulic pump back from Sandy lake. Bill did an awesome job as I finally have 1 finger steering at all engine speeds. It’s been needed since I bought it 1 1/2 years ago. Merry Christmas to me|
Still have to put dads 6060 clutch in fresh back from Rick.
Then the 390 AC haybine with Tiger teeth install. Go over the bailer to get ready for hay season.. the Oliver planter needs some TLC. Life as a farmer full time or part time never ends. And I love it|
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 10:03pm
Still working on my grandpa's 1951 Chevy 2 ton truck overhaul...school's out now for a month, so maybe I'll get it finished before too long!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 11:28pm
Drained 2.5 gallons of antifreeze out of the oil pan of my new project 7040 Powershift, threw two batteries on her, cranked, got pickup on it to jump start, crank more, not much smoke, investigate dangling wires, hook lift pump back up (has the updated dual spin-on filter lift pump kit) crank and she fires up!
Drove it off the truck! Powershift seems crisp! :)
Now I need to find out where this antifreeze leak is coming from... :)
I am also figuring out why my 2-155 White project will not shift into two gears. I am afraid its a rusted shift collar internally, but I may get lucky and find its just in the linkage. I feel bad about that one, turns out the jockey that sold it powerwashed it and didnt realize it had a cracked manifold, and got water down the engine. Had I known this I would have tried to make it run the day I bought it, but no, harvest was coming and the auction yard I bought it at is very easy to deal with, so it sat till early december. She definitely had some rust in the bores... took starter and muffler off, poured oil down exhaust, barred it over back and forth till I could roll it over, rolled it over 10 times, re-installed starter, and cranked a few times, and she fired up. hopefully the rings are OK...
Tuesday I am going after my 6000 series 8 row White planter. Its set on 36 inch rows, and I have not convinced myself that here in dry western KS I need to be on 30s, so who knows, it may stay as-is, or it get scooted in to 8R30.
You know you are a junk hoarder when you buy the parts before you buy the tractor, I had the front weights I needed for the White 2-155, top link and quick hitch I needed for the 7040, and many bearings and other things I needed for the 6108 White Planter all bought at auction in years past.
we wont even go into the pickup truck projects I have lined up as well... :/
If I get 1 tractor and 1 pickup going and plant 36 inch row corn next year I will be ahead of schedule..... ;)
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 4:04am
waiting for parts to rebuild the d14  lift cylinder, broke 2 wheel bolts off on the d17, spent most of the day laying in the snow drilling them out.  hoping for a better day today...lol
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 4:28am
it's amazing to see how much debris a pack rat can accumulate on 5 acres over 20 years.
so this winter is 75% reorganizing "stuff" and 25% trying to get delayed & half finished projects done - one-at-a-time!
a new pole barn 2nd shop for woodworking will help considerably.
so does being newly retired.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
theropod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theropod Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 4:28am
Taking my B to a media blasting outfit in mid January that will also apply an epoxy primer used on the inside of steel water towers/tanks. Have a local body shop all set to paint the drive train afterwards. Drain, flush and refill the transmission and differential. New rims and tires all around and the sheet metal reinstalled. By late spring I hope to have my 38 rolling and dressed for the dance.
Put the bunny back in the box!
1938 B, 1977 Yanmar YM2200
No private messages:
use email:
theropod AT yahoo DOT com
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 6:19am
Right now I have an 8010 in the shop that we got last spring. It’s got a new floor mat, cab kit, door seals, radio and speakers, and waiting on a head liner. It had a stiff range shifter and a new cable fixed that. Also ran the GPS receiver cable up the left cab post and out behind the lights so that it’s not exposed to tree limbs and blowing in the wind.
It had a dash throttle so I bought a console throttle from a salvage yard and I discovered some brackets in the cab where the cable and lower bell crank mount we’re missing so I fabbed them up and welded them on.
I have some pics I’ll post later.
I also noticed that our 85 8070 has the seat mounted 3” lower than the 8050 and this 8010 which works a lot better with an air ride seat. so I had 3/16 metal bent like the 8070. I got it and a grammar air ride seat installed yesterday.
It’s been a lot of work but it should be nice planting this spring.
8050 radiator was leaking this summer mowing hay so it’s coming in next. It will probably get recored. It is getting a new radio and head liner while I have it in the shop. Still had the original radio and it doesn’t Work very well any more. It has an air ride seat now but it’s getting lowered like the 8010.
There’s a few other od jobs but that should keep me busy for a while.
Edited by wekracer - 18 Dec 2017 at 6:22am
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 7:04am
I worked on my excel spreadsheet for off season maintenance last night. Only 41 jobs on it ugh.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 7:40am
Install new bushings in the front axle of the B.  Clean and reseal the fuel tank on the WC.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 8:16am
I am hoping to go 100% through my 385 planter this winter. I haven't used it for the last two seasons, and it's been sitting outside. It'll need some attention. If the cards really fall in my favor, I'll get my 7580 going also, to put in front of it. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 8:19am
I have to hand it to you Victory, having your jobs on the spread sheet is a good management tool. I wish I had the gumption, or whatever it takes to do that. Seems like when I go to run a seasonal piece of equipment, that's when I remember what I was supposed to fix on it during the off season. Darrel
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 9:23am
  Darrel...I have a 6 row split that I am parting out in case you need some trinkets...Hey, Merry Christmas...Dale
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 12:01pm
I keep a piece of paper with a list that I can add to as I remember even if it is another repair on the same piece and when I get one done I cross it off so it feels like I accomplished something but then I add two more.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 12:57pm
I do that too then usually lose the paper and forget most everything I wrote down then remember suddenly next season.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 7:48pm
Not a bad idea Dan simple and cheap. Mice probably eat mine.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 8:58pm
I've got a chalk board on the wall in the shop.  Problem is some of the things listed on it have been there for 10 or more years.  Maybe I should just erase it and start fresh....
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 10:16pm
I've been thinking about doing that...getting a chalk board to keep track of things. But I'd probably be in the same boat...some things stay there for several years!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 10:39pm
water pumps on 8070's
rear lights on 8070
throttle cable on 8070's
wiper switch on 8050
stadium lights on 7080
UC radiator and belt
Uncle Ken's WC
Shoot lots of pool
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 7:09am
My first objective is to stay warm!!  Everything after that is gravy......
I HAVE to get carb kits for the WD45, one for a D-17 and the CA.
So it'll be boiling them (Dick L's recipe), cleaning, clearing and then new parts.
Other than that, I can't get much done,,,,,,I don't have a heated shop/garage as yet.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 7:30am
Fix major leak coming from hydro area on L2 and install new raddle chains, reroute electrical cables to cab and better seal up cab from mice.
On the corn head, rebuild stripper plates and reverse snapping roll flutes, new drive chains, gathering chains and sprockets.
Get my 1616H mower running that hasn't run in over a year. Think key switch of something, no spark.
Put led lights on 7050.
Not sure on order of things and am pretty sure not all will get done.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 6:07pm
Not A-C related, But I gots a new set of skins ordered fer the newest K'boter, gotta pickup the Dixie chopper from the shop, later this week, and gots a payin garden tillin job, tomorrow...
Spent the warm weather yesterday and today, bush hoggin the unfarmed steepest hill on the farm.  Today, was 3-1/2 hrs stump grindin about a thousand little gum tree stumps, leftover from the bush hoggin...Wink
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:05pm
Figured I would work on something a little newer rather than the Model T's this winter so I'm building an old school hotrod like they would have in the 50's from the ground up with scavenged parts. Model A frame and suspension dropped 4" with a 1930 Model A coupe body. Rearend, steering sector and tranny from a 1947 F1 pickup. Front end from a 1939 donor. Hydraulic brakes. 1949 Mercury flathead V8. Some assembly required.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:23pm
Put as much sand on the groung as mother nature will let me as I'm a dredge operator 6 days a week, and I help at the farm the other 7.  My neighbor from 40 years ago has a early 190 gasser, with a junk cab. ( I remember the tractor as a teenager) He want's me to add a second remote and install a loader. The cab isn't going back on.  Dad has completely rebuilt 4 rows on the 630 corn head for the L3, the snap roller bearings went out on the other 2 rows this past fall. Lots of little stuff, 4 rears on the 8070, it all takes time. Like everybody else, seems like there is always something I should be doing. My son has his FFA mechanics project too.
Hey Lonn, get some cats and leave the cab door open, many a morning we go the shed and a cat is sitting on the seat.  CAT FOOD IS CHEAP.
Leon B MO
Edited by Leon B MO - 19 Dec 2017 at 8:26pm
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 9:50pm
Well, my projects include but not limited to:
Repair the flashers on the 7045.
Repair a hydraulic leak on the 7045.
I'm getting close to having the XT with an L combine engine operational, waiting for a few parts that are on order and I need to drop the steering cylinder down an inch.
Make some repairs on the Hesston discbine and New Idea hay rake.
AC 7045
AC 190XT with Gleaner L engine
Hesston, New Holland and New Idea hay equipment
OK, so what's the speed of dark?
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 10:42pm
Winter projects....
D15
- weld up seat frame holes that are wallered out, all the pins have worn through the bushings and cut into the frame, and install new bushings
-new seal on PTO, and lower seal on power steering shaft
-replace all gauges and switches
-rewire tractor (new harness is here but need to get into it)
-replace valve cover gasket
-drive out brake cross shaft, lube up and reinstall, check brake settings
-remove heat shield on side of transmission, straighten and clean
-replace right fender and straighten brace
-remount hydraulic quick connects so they will work
-change seat
-new tires and rear rims
-various cosmetic improvements
-sand blast and paint
etc.
5015
-valve cover replacement
-find engine oil leak and fix
-new blades on mower
And if there is any thing left by spring, I can work on it next winter....
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 7:01am
Need to look into my B with the loader.  Starts good, runs good, but shoots oil out the exhaust.  Not quite sure what I will find, hope it's not too bad.
