WD hand clutch pivot
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch pivot
    Posted: 06 Dec 2017 at 11:24am
Can it be changed with tranny still in  frame?
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 11:47am
It would be easier to just remove the side rail. Pull off top of trans. I couldn't get mine to move out so I cut it of and drove it through. Freeze the new pin a bit before installing will help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 11:50am
Should have also said that except for early tractors there are bushings in the handle to change. I had the right side drill to just drill the old ones out. I would think you might be able to drill out one that never had them. If you need the drill but if you don't have that size just let me know and you can borrow it.
Actually just put the weights on I got from you this past weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 4:00pm
Send me a text Gary 540-953-1556
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 6:51am
I used a six foot pry bar, used the frame rail as a pivot and pushed it in.
