39 B Steering Shaft Question
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: 39 B Steering Shaft Question
    Posted: 29 Jun 2010 at 9:45am
Finally got the old broken steering wheel off the column of the 39 B.   Inside the top of the shaft housing was a single round rubber insert that was melted quite a bit by the transferred heat of my torch.  Rusted nut, rusted wheel center... it was a multi day project soaking and tapping and made me work HARD to separate.  The torch finally won.    The only part inside the shaft support tube was the rubber spacer doughnut around the shaft... is there supposed to be more at the top of the tube on a 39?   Any type of bearing or  hard bushing assembly?     Appreciate the help.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 11:36am
Took one apart the other day, there was a steel bushing on the shaft, then rubber then the outer housing.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 3:20pm
Anything will work, wood soaked in oil. I made one out of nylon.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:54pm
  we have replacement bushings that work good  1-574-342-4545
