1953 WD45 hydraulic pump
Adam12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam12 Quote  Post ReplyReply Direct Link To This Post Topic: 1953 WD45 hydraulic pump
    Posted: 27 Jun 2010 at 8:00pm
I removed the hydraulic pump from my 1953 WD45 because it would not lift the arms when cold, I found that one of the plungers is stuck in the main body below the surface so I cannot get any thing on it to remove it. I was wondering if anyone else had run in to this before and how did you get it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 11:16pm
I had one stuck in a B pump. I soaked it good with Kroil and started lightly tapping on it. It finally started coming up after working at it for a couple days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam12 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 5:41pm
Thanks for the advise, I ended up getting it out today using some zep45 and a small hammer and punch.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:34pm
We used to weld big flat warshers on the stuck plunger then pried it out with a heavy screwdriver.  Remember, new parts were just a step away then.  Now you have to do it like you did above.  Congratulations!!
When you remove the valve body be certain to keep them in order when replaced and immersed in something like diesel fuel so they will not enlarge or shrink.
Good Luck!
Bill Long
Bill Long
This page was generated in 2.926 seconds.
