6 volt battery trickle charger?
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Topic: 6 volt battery trickle charger?
    Posted: 05 Nov 2017 at 6:57pm
Anyone have a recommendation for a 6 volt charger that I can leave on the tractor full time over winter?
Edited by 1939Dodge - 05 Nov 2017 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 7:08pm
We sell 6V Battery tenders, but you can probably get one locally. Deltran is a good unit. Also, Battery Doctor is another good brand...
Steve@B&B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 9:50am
You want an automatic battery maintainer, not a plain trickle charger. The simple trickle charger will overcharge the battery if left on continuously. The automatic battery maintainer has a voltage regulator (and it needs to be for a 6 volt battery) that keeps it from overcharging the battery.
Gerald J.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 10:19am
If you don't want to spend a lot of money, go with Steve's recommendation. If you also need a battery charger you might be able to kill two birds with one stone. Google "smart battery chargers" and see what comes up. Finding one that does 6 volts might be a challenge. These act as 3 stage chargers and put the charger in the "float" mode after the battery is charged. Again, it depends on if you also need a charger. You'll pay more for a smart charger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 10:49am
In the 'good old days' you'd use a 12 volt charger and put a 6 volt light bulb in series with the 6 volt battery. A sI said in another related thread(solar 6 volt), I can easily code the microcomputer to do the 'maintainer' 3 step process BUT I can't buy the bits and pieces for what they sell complete 'off the shelf' units for...
Any of the SCR based 'chargers' should work as 'maintainers' as once the battery is up to snuff, they shut off until the battery 'drains down' a tad...
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 11:16am
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 4:41pm
I have this one.
It will not charge a discharged 6 volt battery, but it will maintain a charged one.  I bought it for my motorcycle a couple of years ago and it will charge a 12 volt battery slowly, then maintain it.  I subsequently got rid of the motorcycle and now use it on my B to keep the battery from discharging over time.  You'll have to ask the electronicals why it won't charge 6 volt batteries.
Edited by HoughMade - 06 Nov 2017 at 4:42pm
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 5:28pm
someone on here has the best setup, I've seen, He took a solar panel, offn a 6V 'lectric fence charger and put a coupla wires wif alligator clips, to the battery...  I'll let him post the pics, if he wants to...Wink
Edited by DiyDave - 06 Nov 2017 at 5:28pm
