Allis chalmers 170 injection pump static timing
Ben s View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 170 injection pump static timing
    Posted: 03 Nov 2017 at 7:07pm
How do you check the injection pump static timing? Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 8:53pm
If I remember right, you remove timing window on side of pump, rotate engine until pump mark lines with straight edge of snap ring. Then mark on flywheel should line with hole in side of torque housing. If this is wrong, some one correct me.        MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 5:22pm
Normally on a CAV you'd just line the mark on the flange with the mark on the front cover. There are some that would line letter "C" up with the flat edge of the snap ring like Mack said. My question is, why are you concerned with the timing? Odds are there's something wrong here right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 5:28pm
The reason why I'm concerned is the tractor cranks over very hard had starter checked put welding cables on and a 1000cca battery I just want to check every thing over I have not had this tractor long and don't know the history on it thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 5:58pm
I'd check the starter before I messed with the inj pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 2:00pm
so it cranks over hard, meaning it cranks slow? Sounds like it's fighting itself? Does it run good once started? Re-start ok? or ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 2:54pm
You need the BIGGEST battery with the highest CCA to start one of those engines in cold weather. They were borderline on needing two batteries.  This also means good big battery cables and clean connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 4:30pm
It cranks slow and hard like it's fighting itself it smokes bad when cranking then I give it a shot of ether then it will start ok all day long and once running it runs really well
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 10:58pm
Time for new or rebuilt starter.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 6:07am
Christmas is coming.  Ask Santa for a gear reduction starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben s Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:02am
Might have to lol thanks
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 3:38pm
as other said,New Starter and a block heater in cold weather!
