CA snap coupler Post Hole Digger
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Topic: CA snap coupler Post Hole Digger
    Posted: 26 Jun 2010 at 11:11pm
I just bought a snap coupler post hole digger that came off of a CA. It is orange and presumably Allis. It has about a 2" dia. pipe "U" shaped main frame. The ends of the "U are flaired out and looks to fit over the pins at the rear of the CA. There are also some brackets off the top of the main "U" frame that come up and attach to the snap coupler latches for lifting. I will post a picture when I pick it up. In the mean time, would anyone have a picture of one that was sold by Allis for the CA's.
Thanks,
Mike
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 7:47am
I do not have a pictue but there was one made by Allis Chalmers.  It was a Roper Post Hole Digger.  We sold several and they worked very well.
If I recall they fit very easily and work well.
Look forward to seeing a picture.
Enjoy!!
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:03am
Bill could you clarify something for me. You say there was a PHD made by Allis, it was a Roper. Do you mean there was a PHD made by Roper for Allis tractors? I don't think Allis ever made Roper products. The same thing happens when people see the tag on a Freeman loader. Allis didn't make Freeman loaders but had them produced by Freeman to fit Allis tractors.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 10:05am
Ropers have a channel iron frame. It must be an Allis one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 10:39am
So Allis did actually build a PHD?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 2:29pm
 Roper built the unit for AC.  The # 10 was AC built in the LaCosse.  And I think it was 3 PT only?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 2:31pm
That should be in the "LaCrosse Plant."  Sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 7:59pm
I'll be going home tomorrow.  I will check with Pop's 1960 price book.  Information in there is usually good.
Good Luck!
Bill Long
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:42pm
The # 10 did come in 3 PT and SC. I have a SC one and have seen 3 Pt ones.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:24pm
I am home for a day and have looked at Pop's 1960 Price Book.  It shows a post hole digger in the La Cross Section for D-17 to D-10, WD-45, WD, and CA tractors equipped with Snap Coupler.  The base machine weighed 236 lbs and listed for $ 169.00.  There were various augers that could be used from 6" to 24" with prices ranging from $ 63.00 - $ 137.80.
The equipment was shipped from Indianapolis, Indiana which indicates it was not made in an Allis Chalmers factory but in an after market operation like a roper.  I definitely know it was not a danhuser since they have a very distinct gear box while the roper looks like a model A Ford Rear End.
Hope this is some help.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:46pm
Bill,
Thanks for your research, it is much appreciated and I had just posted an update on my post hole digger with pictures prior to reading your responce.
Thanks again,
Mike
This page was generated in 0.031 seconds.
