G on e-bay in KY
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: G on e-bay in KY
    Posted: 26 Jun 2010 at 6:12pm
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 6:21pm
Edited by GBACBFan - 26 Jun 2010 at 6:24pm
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 6:42pm
That's one use for military tires and a whole lot cheaper than the real ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 2:25pm
You're right, Lonnie. If the wheel centers were painted orange, and the edges of the wheel painted silver, it wouldn't even look too bad. This tractor was at a show in Central Wisconsin last year.
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 4:15pm
So, is this tractor ideal for truck farmers??????????
Adam
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:31am
Your choice of two widths!
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:38am
I didn't realize truck rims would bolt right up to a G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 8:32am
Boy, if I didn't know better, I'd say those wheels in Larry's pics look like the old split rim "Motor Wheel" that IH used on their trucks from the late 50's-early 70's as well as the Army. Pretty interesting. The large holes are the bolt circle for IH. Looks like new holes where drilled for the G model...
Steve@B&B
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 9:28am
It looks like he cut a disc to drill the mounting holes to fit the G. The outside of the disc is welded into the truck rim and the inside hole matches the G hub. It's a simple adaptor.
This page was generated in 0.079 seconds.
