190 xt transmission problem
Coalminer618 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coalminer618 Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt transmission problem
    Posted: 22 Oct 2017 at 7:15pm
I was discing with my190xt. It locked up in transmission or rear end. You put trans in neutral pd in low it will move. Put in any gear an pd in low will kill motor. Any ideas
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 8:00pm
You have a broken shifter fork it's stuck in one gear. And the forks won't disengage that gear when I gagging another. A trany in two gears won't move at all. When you put it back in neutral your in whatever gear has the broken shift fork. THIS IS JUST A EDUCATED GUESS based on the information you have given. Remove the floor plate and shift tower to verify. Fortunately a shifter fork can be replace without splitting it. Don't drive it anywhere a broken shifter fork going between the gears will really destroy more parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 10:06pm
Check transmission oil, sounds like it is low on oil and has welded low gear bushing to pinion shaft. Put it in first gear and see if it will move.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coalminer618 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 7:11pm
It moves when in first gear. No shifting forks broke. Could it be pd trying to go in high an low at same time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 8:21pm
You said put transmition in neutral and PD in low it moves. If this is correct it's still in gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 9:02pm
Just what I said to start with. It moves in first gear, because first gear is welded to pinion shaft. Good luck in pressing it out.    MACK
