Loader for 6080
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: Loader for 6080
    Posted: 22 Oct 2017 at 8:24am
Found a 6080 4WD but it has no loader, where would I start looking and how much should I plan on spending?  Otheres I have seen plumb into and operate by the rear remotes, how do you use the remotes if you have the loader on?
This tractor has no muffler, only a chrome pipe, good or bad?  Also has 18.4 x 34 rears, it has < 2000 hours showing, so did they come that way?  Or should I be suspect of the hours?
Bill
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 9:11am
Mine came with a factory loader.   When I need a remote I let the bucket drop so there is no pressure on the lines and unhook that set of remotes to use.  If I need both it is fairly easy to unhook the loader with the factory stands.  I think eventually I will set up a joystick on the power beyond, just haven't really needed to yet.  Our local tractor salvage has a selection of loaders, maybe check in your area?
