Plow lift and counter weight
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Plow lift and counter weight
    Posted: 11 Oct 2017 at 6:35pm
Now the old yellows the plow and counter weight in back worked together so it was easy to lift plow. Question is does the 900s do the same. I could go look but if any of you know me that's not so easy lol. My young nephew has one of our 914s and has been mowing at his house. He was telling me how he wants to get a plow and plow snow. So me and dad told him that we would give him a plow. But that tractor doesn't have electric or hyd lift and told him he wouldn't be able to lift it. If the counter weight, Works like the ole yellows on the 900s then we would set him up with one.
Thanks
Edited by Mikez - 11 Oct 2017 at 10:25pm
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 7:36pm
If you have rear lift don't see why it won't work
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 11:52am
No, the RBT's, including the 900 series, are setup so the lifts all work the same direction.  When you lift something up front, the rear lift rises as well, unlike the early FDT tractors.  I beleive there was a kit or a method for changing the direction of lift for the rear lift cable, but am unable to find that at the moment.  Peek under your tractor and you will see how the cable wraps aroudn the rock shaft to give it it's movement.  You might get an idea on how to change it.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
ShaunE View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShaunE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 9:43am
If you remove the rear lift cable from the pulley & connect it directly to the rock shaft, it will work opposite like you are wanting.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 7:22pm
I believe my 710 is setup that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 10:40pm
Ok thanks. I can remember some of my first times on garden tractors. Dad put me on the bumble B-10 with snow plow and I plowed the whole back lawn lol. But I was only able to lift the plow because of weight on back. Ill have to look around for the parts to put the rear lift on there 914 so my nephew can plow this winter.
This page was generated in 0.095 seconds.
