WD45 Help
zach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zach Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Help
    Posted: 09 Oct 2017 at 2:21pm
Got a WD45. changed it over to 12 volt, electronic ignition, and rebuilt the carburetor, and got it running. Tractor seems to be using a lot of fuel and burning really hot. At night the muffler and exhaust manifold will be glowing red hot, and it is heating up the hood and bubbling the paint? anyone else had an issue with this? any help would be appreciated.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 2:22pm
Timing or exhaust valves not closing, or exhaust restriction.  Most likely timing since you were in there with the conversion.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 6:30pm
Late timing for sure. Take the the inspection plate off under clutch. Get a timing light out and time it for the "F" mark. So with the engine wide open the F has to be straight down.
A bit of a guessing game as there is not a second reference to go by. Straight down to the best of your ability. That "F" is 30 degrees. F for fire. There is another reference mark just a line if I remember correctly - that is zero. Hope that helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 1:13am
Wondering if you had any luck resolving this issue?
zach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zach Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 6:18am
yes I did. timing was way off. running like a top now! thank you
