B Water Pump Fan Belt Pulley
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Topic: B Water Pump Fan Belt Pulley
    Posted: 23 Jun 2010 at 11:55am
OK, I give, how do you get this pulley off the water pump shaft.  Tried heat, rustbuster, a puller...??????
Bob, North Carolina
1949 B
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 11:59am
When the 4 bolts are out of the fan blade. It should come off. I suggest a puller.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 12:48pm
Sometimes a lot of debris (dirt, oil, etc) gets caught behind the pulley. Remove the 4- 1/4" bolts and fan, then try wiggling the pulley to bust thru the debris.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 2:45pm
Lots of heat worked, 61 yrs of rust!
Bob, North Carolina
1949 B
