ALLIS-CHALMERS D 21, 7 BOTTOM, ON-LAND SEMI-MOUNT.
R Albart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Albart Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS-CHALMERS D 21, 7 BOTTOM, ON-LAND SEMI-MOUNT.
    Posted: 12 Sep 2017 at 7:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 7:42pm
A21 with 24.5 32,s could probably handle it, but dam itd be hard on the 3 pt hitch
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 8:01pm
I pulled a 7 bottom pull type for a few years with D21 with duals but had it weighted to the hilt, power was ok but hard to get it to the ground.
rodnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 9:14pm
IS IT FOR SALE ?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 6:07am
I have a plow like that. I need the extra offset front plate to use it with my 220 with duals because the dual makes contact with the front plow wheel on a right turn. Next year I'll hook it to my 220 fwd with single rears. Model 3000 plow
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 7:08am
So what about it?  I don't see a D21.  Don't see the D21 pulling that plow.  Does it?  Wouldn't for me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 8:47am
My D-21 would NOT pull that plow around here.  Have not tried with my 220 2wd with 20.8 x 38 radial duals weighing 17,300 lbs. I think traction would still be a problem. Best chance for me would be with my 220 fwd with 24.5's but I don't plan on adding extra weights on the rear.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 8:53am
Were semi-mount plows a good idea? I have my doubts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Albart Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Albart Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 9:13pm
I think when you got that big they were good if on land hitch, would not want an in furrow one that size.
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 10:05pm
Traction Booster makes it work.
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 10:05am
Better be easy plowing ground for 7 bottoms. 5 here is loaded hard. Our d21 will pull 6 but it tends to carry the front wheels. We have a starter weight and 4 slabs out front. The rear has big inside and 2 doughnut weights out side
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 10:26am
Norm stated in his book  that the in furrow plows pulled easier than the on land hitch style.  Im on the same page as calebNok,  must be easy ground we pull 6-16 with 7080, 6-16 on land with 7580 and its enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 10:38am
Well, yes, they are a good idea.  I'm not sure what your doubts stem from....But they plow just fine, and one great benefit, if you start getting stuck or hung up some how, you can lift the back end out of the ground with the tailwheel.  In other words, can lift the plow more completely out of the ground when you begin to get stuck.  Then when the plows get big....like 5+ bottoms, you're not carrying all that weight so far back.
