Gleaner F platform repair question
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F platform repair question
    Posted: 12 Sep 2017 at 7:43am
How do you get the pulley off the main shaft that drives the sickle. Pulley drives the anger and it has a piece on the end that drives the sickle.   Can't seem to tell exactly how it's attached.   I thought I'd ask on here before I get it tore completely apart in case somebody has been in to one. Need to replace the bearing and holder behind it.
Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 7:58am
screws on -   turn it in the direction of rotation to get it off - usually requires heat - big wrench pipe or chain - and a long cheater...
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 1:42pm
Like Tbran says, except I've always had good luck after heating it up then using a larger metal punch & ball peen hammer to rap it hard for beginning to turning it off. Place the punch's drive end just inside lower spokes where spoke attaches nearest shaft. Sheave is cast, so it can break or chip if punch is not solid for good hit.
