Gearing for wc
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Topic: Gearing for wc
    Posted: 09 Sep 2017 at 10:18pm
Can a wd trans. Fit in a wc and r they geared diferently. Can a wc reared gears b changed to lower gear ratio
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 8:40am
rc gears can be put into a wc housing,easier to swap the whole rc rear-end,geared about 1 gear lower
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 12:20pm
Tranny cannot be swapped. An RC ring and pinion is what most use to get slowed down. Or find a 2 speed gearbox.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:01pm
Did not know they made a 2 speed gear box for wc. Do they mount behind trans. Any Allis folks have one?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 8:14am
it goes on the pinion shaft behind the trans where the cult lift is and you have to have a short pinion like on the styled tractors with the release for it to fit.  there are overdrives and underdrives and are some both I think.  several different companies made them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 6:07pm
Cal u don't have one do u? What about yhe unstyled wc,is there a different one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 7:45am
no I don't have one.  would like to find one for my brothers 38 unstyled.   couple guys in my club run them.  as far as I know you cannot use one in an unstyled tractor unless you switch out the pinion in which case usually just means the whole pumpkin as its easier.
Edited by CAL(KS) - 15 Sep 2017 at 7:46am
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 7:44am
Shereman is Overdrive or Underdrive.  Can be found but pricey.  I used a complete rear end out of a speed patrol that is a lower gear like a RC.  second gear is about what old first gear was.  1st is low and reverse is slow
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
