Gleaner L3 Bin
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L3 Bin
    Posted: 06 Sep 2017 at 11:29am
Our L3 seems to be losing the gap between the bottom of the bin and the unload auger.  Like the bin is sagging.  What would be causing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 12:04pm
The elbow/swivel is sagging. Pretty normal as they get older. Look at a much newer rotary combine and see the brace the have installed from the frame upwards to the elbow to support it.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 2:05pm
Excellent!  Thanks for the guidance.  Every completely remove the bin to redo the floor sheet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 2:32pm
Nope. Have a piece rolled into the correct shape and install it in chassis.
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 5:18pm
May Wes sells a bin floor poly sheet with the side brackets. I installed one in our M3 as the bent bin auger wore the floor away. Took a couple of hours to install.
Edited by jbirnsch - 06 Sep 2017 at 5:21pm
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 5:24pm
I know a guy who replaced the entire floor sheet, and it was somewhat labor intensive, but I imagine not nearly as bad as other colors. mostly the clean grain elevator disassembly was the major part.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 5:33pm
That's spot on! Imagine doing it in a Deere --00 or --20 series combine! 5 auger troughs in a 7700 and I think 2 in a 7720.
I'll stick with Gleaner! Big smile
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2017 at 8:44pm
Removed bin as part of combine rebuild. Pretty big job but can be done. Put a new stainless steel floor in on the outside (no ridge this way to catch seeds) of the bin bottom up each side (front and rear) about 2 ft. Had supplier pre-drill the stainless for the rivets. I figure it will be there long after the combine is done. Worked out good.
