HD11 allis chalmers
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Topic: HD11 allis chalmers
    Posted: 05 Sep 2017 at 5:38pm
I have a HD11 when I go to engage it using the clutch/brake control arm I have to hold it in a certain place before it will actually take off once it takes off it's like I have to hold it there to operate everything else and once it falls out of that spot it quits pulling until I find that spot again anyone ever had this issue or might know what's actually going on here this is my first just bought it a week ago I'm totally clueless
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 11:20pm
Welcome
The clutch needs a adjusting from the sounds of it. People here are helpful but getting a operators book for your model will be very useful.
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 11:44pm
Thanks Ray54 the guy I bought it from texted me earlier today and told me he found the book that goes with it I'll stop by tomorrow to pick it up and go through it to see what I can find out thanks again!!!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 9:58am
the clutch needs to snap in over center with XXlbs of pull.  when you go through your manual you will see.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2017 at 3:19pm
A service  and parts manual are a "must-have".
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 10:54am
I have a parts manual where can I find a good service manual
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 4:57pm
Can anyone help me with adjustments on my HD11 clutch is it like a PTO clutch or like a semi clutch pics sure would be helpful I have ordered a service manual it won't be here for 10 to 12 days any information would be highly appreciated
Edited by Hunt - 08 Sep 2017 at 5:45pm
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 5:16pm
Pic
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 6:22pm
Nice HD11 with BUDA ALLIS motor and the track are too much loosed
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 6:28pm
Thanks you know anything about clutch/brake
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 2:09pm
Can anyone tell me year of Hd11B6361
Edited by Hunt - 09 Sep 2017 at 2:10pm
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 4:12pm
Late 1960
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 7:36pm
 It has a late model quick drop ram on one side , does the blade function ok they are meant to be a pair ? when lowering the blade does it twist ) left hand side would release quicker and the right ram would have all the weight .
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 9:26pm
Looks like one of the late ones with the dry clutch.  They have a ring type clutch, you take off an inspection plate on the top to adjust, loosen the retainers and turn the ring I believe...  Interesting to see that one quick drop valve for sure- you could adjust it to minimize the effect.
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 12:37pm
Yeah it actually works really well both sides come up an down evenly their might be a slight slight difference
Hunt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 12:38pm
Thanks very helpful I read a little on dry and wet clutches really didn't know the difference until now lol it sure is a learning process I'm trying this is actually my first dozer
Edited by Hunt - 10 Sep 2017 at 12:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 1:58pm
The idler is at the end track frame and you have to make turned boushing or removed a link track and final drive sprocket is leaking.
This page was generated in 0.112 seconds.
