Allis C puller
jfrdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Topic: Allis C puller
    Posted: 04 Sep 2017 at 9:47am
Will a D15 manifold and carburetor on the allis c engine make more power? If jot what is the best choice of manifold and carburetor for a division 1 allis c? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 1:28pm
It will not be a direct bolt up fit, although a good machinist can get the job done. None of the bolt holes match but the ports match up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 1:36pm
Are the ports larger? Would it be worth porting the c manifold rather than making a d15 manifold fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 4:13pm
The ports match as I said above. You can lay one gasket on top of  the other a see this. However if your only running in division 1 I hardly see the end result worth the effort. Now If you had bored stroked and increased the RPM, the benefit would be well worth doing the work. There are a lot of little tweaks you can do to a "stock" engine to get the most out of what you have.  Just swapping to a larger venturi in the carburetor you have is most likely all you need.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2017 at 5:50am
Tire slip is what stops me. Solve that problem and you may have a winner unless you just plain power out with traction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2017 at 3:42pm
Thanks for the reply, I have herd the WD carburetor would be a good up grade. Is this true? Thanks again
