D19 Weight
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D19 Weight
    Posted: 28 Aug 2017 at 10:36pm
Can anyone give me an educated guess what this early D19 gas tractor would weigh. It has 18.4-34 tires with cast centres, and a 3ph off of a 190, I think. I would like to pull in the 6500 lb class on thurs night. It is serial # 1041.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 5:54am
It would be close without calcium.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 6:07am
Per 'Tractor Data' web site
6650 to 11,210 pounds.
Gary
http://www.tractordata.com/farm-tractors/000/0/1/19-allis-chalmers-d19.html
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 8:24am
Brian you'll be close mine is 5500 with no hydrolics no snap couple and a real light front end with cast CT wheels and no water
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 10:49am
Ok thanks guys. I seen the tractor data, but was unsure if that was with 3 point or snap coupler. I will be looking for a narrow front for this tractor. Preferably in Ontario. Also do the make a hub that you can bolt a 38" rim to. I would like to put 18.4-38 on it.
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 9:27pm
We pull 6500 with a narrow front diesel but nothing else taken off. I would guess youll be over weight.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 10:32am
Looks like one of the Nesbitt tractors!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2017 at 8:04pm
Well whats it weigh how did you do
