B starter question
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: B starter question
    Posted: 26 Aug 2017 at 6:21pm
I have a newly rebuilt B starter I acquired in a deal.  Unfortunately, it has the stud for power--not the mechanical switch.  Can I modify this stud somehow to make it work with the mechanical switch?  I don't really want to set it up for electric start.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 7:10pm
Being a starter is electric start.
I think you mean a Solenoid.
Gary
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 8:17am
You can switch the threaded stud with the solid stud for the starter switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 10:28am
As Dick mentioned, you can change the stud over to the pad style for the switch, but actually, the Starter with stud working with a Starter relay actually works much better than the old style switches which once worn, causes starting issues. You can hide the relay in the tool box, and run the cable out the side hole where it normally would exit to the Starter motor. Your choice...
Steve@B&B
