Need help with part no. on 460 loader |
mark-east-tn
Joined: 06 Oct 2009 Location: Rutledge Tn Points: 761 |
Topic: Need help with part no. on 460 loaderPosted: 24 Aug 2017 at 11:21pm |
Ive looked on agco parts book web site and have not had any luck , my tilt cylinder on my 460 loader is leaking a little and id like to order a seal kit for it if anyone can help with part no. . Its the cylinder that tilts bucket .Thanks
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3812 |
Posted: 24 Aug 2017 at 11:35pm |
There was 2 different model 460 loaders. 1 was for the 160 and the other was for the 6060,6080. If its the newer one for the 6000 series I have a seal kit in the shop I can get a number off of.
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
mark-east-tn
Posted: 24 Aug 2017 at 11:41pm |
yes its on a 6060 thanks for help .
V8cat359
Joined: 28 Feb 2017 Location: Pulaski, Tn. Points: 536 |
Posted: 25 Aug 2017 at 5:31am |
What is the difference between the two loaders other than the oil reservoir in the left bracket on a 160?
LB0442
Posted: 25 Aug 2017 at 8:23am |
I resealed both the tilt and raise cylinders on my 6080. Part #71503831, all 4 are the same.
mark-east-tn
Posted: 25 Aug 2017 at 8:55am |
Thanks I'll check with Brenda and see if she can get me one , thanks again for the help .
LB0442
Posted: 25 Aug 2017 at 2:50pm |
That would be the exact same place I got mine. Sandy Lake is great to deal with.
Tswarner67
Posted: 19 Apr 2025 at 4:24am |
Touching base on this post . What’s the difference between this and one for the 160? My 160 tilt cylinder is leaking pretty good . Would the same kit work for it ?
DrAllis
Posted: 19 Apr 2025 at 8:13am |
Two completely different loaders built years apart. A 460 loader for a One-Sixty tractor uses seal kits from the 400 or 500 series loaders as used on the D-series primarily.
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1768 |
Posted: 20 Apr 2025 at 8:40pm |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
