WD Nelson vs Stanley Muffler
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: WD Nelson vs Stanley Muffler
    Posted: 23 Aug 2017 at 8:22am
When you look in the top of a Stanley muffler, you can see right out the other end.
Is the Nelson the same way or is there a baffle to force it through the body of the muffler?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 8:25am
Are Nelsons still available for the WD45s?
Can't fix stupid
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 8:32am
yes,last I checked they were available through simply filter.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 9:51am
The Nelson on my D17 has a baffle about the middle of the muffler.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 1:40pm
I'm thinking,here just going of memory the nelson mufflers I have both new and old are straight through. I will have to double check tonight. Now I have a Factory nelson off a WD that does have a baffle. FYI the nelson mufflers from the D17 era to present look different from the WD45 and older models.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 8:10pm
Yes, I have bought 2 new Nelson mufflers in the last 3 years for both of my 45s (from AGCO).  Yes, you can also see right through them as well.  They do sound better than the aftermarket muffler, but they are also much more expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 2:06pm
Don't waste your money on a Stanley.It's a fraction of the cost and a fraction of a muffler.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 2:21pm
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 2:33pm
What is the number for a muffler for a D17 series 3 ?
