Strange CA Engine
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Topic: Strange CA Engine
    Posted: 20 Jun 2010 at 10:33pm
Picked up a CA today and noticed a few things. There are no generator bracket holes in the block. It was mounted to flat stock with weld nut and the flat stock had a right angle on the front that picked up a bolt on the front of the block. Also the governor housing has no lube fitting and tube going to it. I don't know B's or C's so could this be one of those? Bracket doesn't look cobbed and lack of lube point doesn't look altered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 10:46pm
it could be an early B motor. Look at the serial number on the left side of the bell housing flange and see if it is a BE instead of a CE motor. no generator mount or gov lube tube on the 1938-39 years
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 12:00am
It's either an early BE block or possibly an RC block. The RC is already 125 cid like a CA, and if it's a BE block it also has likely been updated to later 125 cid specs. Kip
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 8:34am
If there is no number on the flange where you usually see the CE number, look on the boss on the rear of the block, just above the curve. Early B engine numbers stamped there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 9:01pm
Another not so encouraging thing about this motor........I shined a light down the filler hole and saw green ahhhhha!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:37pm
OOOPS, green is not good inside an orange tractor !  could be a bog problem, or could be a freeze plug under the rocker arm. take off the valve cover and look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:38pm
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 11:51pm
When I got my CA and you looked down from the top you saw green too... But it was grass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 7:45am
Steve, that makes sense. Thats exactly where the green is.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 8:41am
I wouldn't mind having a CA but I've got to see some "green" before I can ever get one.  LOL
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2010 at 10:32pm
I bought my first Allis B about four years ago, and haven't had any 'green' since...
