Any D10/D12 anyone is parting out?
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Any D10/D12 anyone is parting out?
    Posted: 20 Jun 2010 at 7:13am
Looking for the snap coupler drawbar assembly yet. Nearly have the tractor restored but still in need of the non traction booster drawbal assembly.
"Better By Design"
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 8:36am
Austin
I used the SC parts from my parts CA on my rehab series I D12 (non-TB; front pump). The parts it up pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 12:47pm
Is there such thing as a Non traction booster Ca?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 5:02pm
Yep. Remove the traction booster linkage rod from the tractor. Then adjust the hyd pumps screws to the hold setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2010 at 6:20pm
Okay...that part will work but there is another bracket the fits under the non traction booster model of the D10/D12.
"Better By Design"
stitchjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stitchjones Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 11:27am
Is the Hydraulic Pump, Hold Position Valve w/ manual lever on a Model CA Allis Chalmers, the same as the early model cam driven one on a D10 Allis chalmers?
I mNeed the whole assembly.
Note:  the number on the Hold Position Valve (CA) is AM 3676-2.  Will this work on a D-10.
Help!!!! I have a paralyzed tractor.
Stitchleg from Asheboro, NC
If anyone is parting out an early model D-10 I do need this part if  one off a CA will not interchange.
Edited by stitchjones - 09 Jul 2010 at 11:32am
