Loader on a D15 series2 |
toddkatz
Topic: Loader on a D15 series2Posted: 02 Aug 2017 at 6:50pm |
I found a allis 500 series loader and the seller says plugs into back of tractor. I have a quick disconnect coupler on back. Do I have enough hydraulics to operate or do I Need the pump on front end?
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
Posted: 02 Aug 2017 at 7:54pm |
The 500 Series loaders are for tractors with 'live hydraulics' like a D-17 Series IV. They use the tractor hydraulic oil reservoir and on-board hydraulic valves. A D-15 needs a 400 series loader. It has the front mounted hydraulic pump for 'live hydraulics. The oil reservoir is in the L/H loader frame, and the bucket control valve and the lift control valve are mounted on the L/H loader frame. Gary |
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Thanks(1)
Posted: 03 Aug 2017 at 12:26am |
The 500 loaders also could be bought with the oil reservoir in the frame using a front pump.
The 500 was made for the D17 through 190 tractors. The 500 used larger cylinders. Pressure is no problem. The speed will be slower using the remotes.
