Coolant in 190XT oil pan
MaxinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaxinSC Quote  Post ReplyReply Direct Link To This Post Topic: Coolant in 190XT oil pan
    Posted: 12 Jul 2017 at 8:21pm
A couple of weeks ago. i was baling hay with my 190XT.  When I was finished baling, as I walked by, the right side of the engine was covered in engine oil. Oil level was ok, so I carried it to the house.  When I was checking the tractor, I found the fan belt loose.  My next step was to change the rocker arm cover gasket.  There was a little gob of vaseline looking junk around the vent tube, but no other signs of anything but engine oil.  Once back together, I found the radiator about 1-1/4 gallons low.  I have to add a little water occassionally but usually less than 1/2 gallon.  I went out tonight to get ready to bush hog the pastures. When I checked the oil level  it was slightly above the full standing mark.  It was about level after the gasket change.  I had a funny feeling, so I dropped the oil plug and about 2 seconds of antifreeze came out before the oil.  I HAD a band temp sending unit, but I feel the tractor did not run hot.  There was no steam around the radiator and it felt normal temps while I was checking out the oil leak in the field. Does anyone have any feel as to what I am facing?  Thanks for any advice or suggestions in advance.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 8:37pm
Would guess sleeve o rings pull pan pressure tester on cooling system to verify.
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2017 at 8:41pm
Sleeve orings and/or cylinders have pin holes. Complete engine overhaul. May have to sleeve lower bores. Been there, done that. I would stop running it immediately or you might be buying a crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2017 at 12:06pm
drop pan fill radiator pressure 5-7 pound and look for antifreeze. sounds like it will show quickly
