B12 pulling tractor differential question...
Kcenderjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcenderjim Quote  Post ReplyReply Direct Link To This Post Topic: B12 pulling tractor differential question...
    Posted: 07 Jul 2017 at 10:30pm
I have been told 2 ways to make the differential into a positractiin. 1st way is to put all the gears so that they are locked into the gear on the rt wheel hub, 2nd is to switch them from HL-HL-HL-HL and make them LL-HH-LL-HH . I'm not getting into welding the gears so that's out of the question. Has anyone done either one of these and which one works?
Thank you in advance.... Jim
digger337 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote digger337 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 12:36pm
Hi ,I used to be a AC dealer, so what your wanting to do goes against by better judgment. But locking the differential in the gear cluster sounds like the way to go. Its the strongest area to do it.I would drill and pin each pinion gear on both sides (you'll need do this in a drill press using cobalt or carbide bitsss) than after assembly tack weld each bolt head to the housing cover,that way if you (when you ) break something it can easily be disassembled to replace any broken roll pins.This does the least amount of permanent damage and can be returned to normal
configuration, just debur the drill holes in the pinion gears.
P.s drill pinions valley to valley if possible and drill through completely so when(if)you should need to replace roll pins.
Thats my Idea 😎
This page was generated in 0.168 seconds.
