Allis Chalmers D17 series 1 or 2
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D17 series 1 or 2
    Posted: 17 Jun 2010 at 6:07pm
Need Help!  I have a D17 that starts and runs great but if I accidently kill the engine after using it for an hour it will not start.  If I let it set for an hour or so it will start and run again just fine.  Is there a fix for this?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 6:12pm
Does the engine turn over fast or slow when it's hot?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:05am
Gas or Diesel?
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:49am
coil
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:29am
I had a WD once.  If you just shut it off it would be a real pain to get started again, whenever you tried, even if I turned the gas off at the sediment bowl after shutting it off.   If I shut off the gas at the sediment bowl and let it run itself out, it would fire right up the next time I used it.  Never did figure that one out!  Good Luck!
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 9:51am
Possibly vapor lock.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 10:31am
Most likely the condencer,or the coil if it turns over OK
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 2:29pm
Gas
danr View Drop Down
on the slow side
danr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danr Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2010 at 2:32pm
what is the fix for vapor lock?
