Wd hydraulic pump gowl
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Wd hydraulic pump gowl
    Posted: 30 Jun 2017 at 7:28pm
I just put my pump back on with new seals. I am now getting a growl from the pump and the main housing is getting hot. The growl goes away when the clutch is pushed in sometimes. It is almost like the pump is still pumping.
So much for the tractor show tomorrow.
Edited by Brampton 02 gt - 30 Jun 2017 at 7:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 7:36pm
Lift arms won't go down at all when tractor is off. Main housing which pump bolts to is so hot I almost can't touch it.
Thoughts appreciated.
This wasn't,t happening when I put pump back on the first time. I had to take it off again when the I twisted off a bolt holding the pump together.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:12pm
Just a chance linkage is adjusted wrong causing pump to want to lift all the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 8:13pm
It seems like it is stuck on high pressure. I hope I didn't put one of the little valves in backwards
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 9:18pm
Spool valve stuck or in wrong.   MACK
