Hand Clutch VS Foot Clutch
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: Hand Clutch VS Foot Clutch
    Posted: 16 Jun 2010 at 5:52am
I know why we have two clutches and their uses but this is my question. Most everyone I know around here with a WD or WD45 always uses their hand clutch to start and stop during normal driving and only use the foot clutch when doing anyting with the PTO. So is this ok, is my question? Basically to never use the foot clutch? It works for me since my foot clutch is resting on the foot rest and I need to adjust it.. but is it the correct or best way to start and stop for normal driving,, ie parades or just moving round bales and such?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 5:59am
Its actually better to use the hand clutch. the hand clutch is a wet clutch, you can slip it during parades and not hurt it. Should use the foot clutch to change gears, at least thats what dad does on grandpa's old WD
1968 D15D,1962 D19D
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 6:18am
What Don said.
"Burgie"
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 7:57am
At the factory schools in the 50's we were encouraged to use the foot clutch since it was a bigger clutch built to handle the horsepower of the tractor.  That said we always pushed for the hand clutch for the very reasons said above.  In my estimation it is an oil clutch and will work better under heavy usage .
Good Luck!
Bill Long
