7060 torque limiter
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: 7060 torque limiter
    Posted: 08 Jun 2017 at 9:39pm
A technician that I am acquainted with, took the torque limiter apart and found
2  Bellville washers. I don't believe I have ever heard of this before. I think it
should function properly if everthing has the right measurements and 1 Belleville
washer is used . Or am I wrong?
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:48pm
they were trying to get to hold with more force machine flywheel a little more problem fixed
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 12:36am
Local dealer on 7060's especially uses 2 Bellevue washers and puts a lock washer under the Bellevue clamp to compensate for the added Bellevue.  They claim that with the extra horsepower of the 7060 over the smaller models, it has a tendency to slip the torque limiter.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:01am
repeat
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:24am
I started double springing them in 1978 for a pulling tractor. A good quality 1/2" lock washer is the same thickness as the second Belleville spring. Longer Gr8 bolts are used in the spacer stools. You can't machine a flywheel enough to get the same results as two springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 12:34pm
use one spring will hold 300 hp
